VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
So, at the Sterling meet I did a leakdown test on my motor, and found a problem with Cylinder 1. 45% leakdown, but 120 lbs of compression. Was tempted just to let sleeping dogs lie, but pulled the head off.
What was going on was clear as soon as we did that, the head was not totaly sealed to the cylinder, off by a very small amount. Instead of having the head recut, I decided to try and lap the two of them together. So, last night I hand lapped them, using ground graphite to check for even contact. I got good contact after the third round of hand lapping (lap, clean, check). Now I need to get the jug back on the block. I have a ring compressor on the piston, but I can't ficgure out how to get the head back on. Do I have to take the piston head off the rod? If so, how do I get it off. It looks like that tis a spring keeper that needs to be removed. Is there anyhting on the rod the needs to be loosened before I can pull the pin out to remove the piston head? Obviously, if there is a trick to getting the jug back on without pulling off the piston head, I'd like to do that. Zach |
VaccaRabite |
The leak is at the head, no question.
Okay, a question. I have all the head studs out of the 1&2 bank except for 1, which will not budge, and I am afraid of snapping it. I have been soaking it for 2 days in Liquid Wrench, tapping with a hammer, and heating the case where the stud is with a MAPP torch and I still can't get it to move. I have tried vice grips and double nutting the top. What else can I try. I really don't want to break this puppy. Zach |
Lo-Fi Version | Time is now: 25th June 2024 - 10:22 PM |
