since #3 cylinder runs hotter, con one use a 2.0 injector |
jimkelly |
Jan 5 2008, 07:42 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
on a 1.7 or 1.8 on the #3 cylinder to cool things down ?
finstermojo |
Jan 5 2008, 06:24 PM
Newbie Group: Members Posts: 40 Joined: 10-November 07 From: new york Member No.: 8,314 |
I had the same issue along with every other type IV and i took a file and cleaned up all the extra flashing in between the fins on the head and all the holes that air is suppose to travel through and would not b/c of the extra flashing from when they make the heads, then i cut a 1/2 to 1 inch of the bottom of the tin that wraps around the back of the head closest to the back of the car so the air would travel by it easier i even opened the fins up al-little more. now both of my back cyl run equal and it came down almost 40 to 50 degrees because of that. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:27 AM |
