DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
here we go
Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Chris Pincetich |
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California ![]() |
The bolt that runs down the middle of the tuna can can destroy your engine case if it is over-torqued (spec is <10lbs), so use new crush washers and be carefull!
Also, the pick-up tube is sometimes too long, so it must be grinded to fit...again, be carefull during instal. (IMG:style_emoticons/default/beerchug.gif) Orange you glad you asked? (IMG:style_emoticons/default/biggrin.gif) |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
The bolt that runs down the middle of the tuna can can destroy your engine case if it is over-torqued (spec is <10lbs), so use new crush washers and be carefull! Also, the pick-up tube is sometimes too long, so it must be grinded to fit...again, be carefull during instal. (IMG:style_emoticons/default/beerchug.gif) Orange you glad you asked? (IMG:style_emoticons/default/biggrin.gif) well... the only dumb question is the one not asked, but... i've been told that doesnt hold true for me (IMG:style_emoticons/default/biggrin.gif) how did you check for clearance of oil pick-up length? is the pick up an extention, what does it look like thanks, mike |
Lo-Fi Version | Time is now: 25th June 2024 - 07:34 PM |
