type4org |
You need PLAID! ![]() ![]() Group: Members Posts: 231 Joined: 13-June 06 From: Oldenburg (Oldb), Germany Member No.: 6,212 ![]() |
Has anyone ever taken the elapsed mileage odometer apart and lubricated it? I'm talking about the box buried under the floor mat at the front of the passenger side which counts the miles in order to switch on the EGR and CAT warning lights on '75 and '76 models after 30,000 miles.
I need to get to mine to reset the counter, anyway (both lights are on now, I'm just over 30,000 miles) and am wondering if there's a way to cure it of its noisiness, it sounds scratchy when driving like it's running dry. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The easy way to cure it: Bypass it. Get a cable from an earlier 914, and install it directly from the angle drive on the trans to the odometer in the dash. Forget about the lights. Done! (IMG:style_emoticons/default/smile.gif)
--DD |
type4org |
The easy way to cure it: Bypass it. Get a cable from an earlier 914, and install it directly from the angle drive on the trans to the odometer in the dash. Forget about the lights. Done! (IMG:style_emoticons/default/smile.gif) --DD I prefer sticking with the original solution, I like things the way they were meant to be (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 03:38 AM |
