> 73 fuel pump mounting question, It has been too long !!!!!!!
David_S
post Jan 20 2008, 01:05 AM
I started tinkering with my project again a few days ago, and am in the process of getting the engine bay back together. Only problem so far is I had to replace the right engine shelf, and I cant remember how the fuel pump mounts ! I attached a pic of the area where the Haynes manual shows it to be, but the pic in the manual isn't the greatest. Also in the pic, what mounts in the slotted J shaped bracked above the motor mount? It has been too long ago since I tore this thing apart and I screwed up and didn't take enough pictures !!!!!! TIA
swl
post Jan 20 2008, 07:51 AM
Here is the 'as installed' position. The pump mounts by way of 2 rubber bushings - noise and vibration isolation. You can just see one at the top of the pump.
David_S   73 fuel pump mounting question   Jan 20 2008, 01:05 AM
cwpeden   I replaced mine and didnt know either, this is wha...   Jan 20 2008, 02:33 AM
cwpeden   close up   Jan 20 2008, 02:36 AM
swl   Here is the 'as installed' position. The ...   Jan 20 2008, 07:51 AM
SirAndy   Here is the 'as installed' position. The...   Jan 20 2008, 11:48 AM
Cevan   Why not relocate the pump to the front?   Jan 20 2008, 06:29 PM
ClayPerrine   Why not relocate the pump to the front? :agree:...   Jan 20 2008, 09:24 PM
David_S   Why not relocate the pump to the front? :agree...   Jan 20 2008, 11:12 PM
SirAndy   Why not relocate the pump to the front? :agree...   Jan 21 2008, 10:37 AM
Phoenix914   I just replaced the mounts on my '73 because o...   Jan 21 2008, 12:02 PM
ConeDodger   In a properly maintained car you should not experi...   Jan 21 2008, 12:53 PM
SirAndy   At the pressure in an EFI system vapor lock shoul...   Jan 21 2008, 12:59 PM
KELTY360   In a properly maintained car you should not exper...   Jan 27 2008, 01:11 PM
stephestrad   In a properly maintained car you should not exper...   Jan 8 2014, 10:24 AM
Dtjaden   In 1973 I had a new 914. I was in Minnesota at tha...   Feb 24 2014, 09:47 AM
KELTY360   In 1973 I had a new 914. I was in Minnesota at th...   Feb 24 2014, 10:34 AM
swl   I suspect that the original engineers located the ...   Jan 22 2008, 11:42 AM
David_S   So ....going by the pic that SWL posted .....the f...   Jan 27 2008, 11:14 AM
swl   definitely not the engine tin. it stays with the ...   Jan 27 2008, 11:29 AM
David_S   SWL ......The small hole in my pic is about 1/4...   Jan 27 2008, 11:39 AM
swl   My pump is not installed at the moment - would you...   Jan 27 2008, 11:46 AM
swl   hmm. on your pic there are a couple of light spot...   Jan 27 2008, 11:50 AM
David_S   A pic would be wonderful!!!! I d...   Jan 27 2008, 11:56 AM
swl   just had a quicklook. I tried to grab a pic but I...   Jan 27 2008, 12:20 PM
David_S   SWL ...not a problem. I know what hibernation mode...   Jan 27 2008, 12:27 PM
swl   Here is the (shitty) pic of the mounts. I'm ...   Jan 27 2008, 12:48 PM
JawjaPorsche   I moved my pump to firewall twenty years ago and h...   Jan 8 2014, 10:44 AM
914_teener   :agree: I moved mine exactly as it appears above...   Jan 8 2014, 11:14 PM
stephestrad   Thanks to you both for the feedback and the locati...   Jan 9 2014, 12:33 AM
Shindog1961   I have heard that this pump location requires you ...   Feb 23 2014, 11:58 PM
914_teener   No problem with the fuel pump mounted on the firew...   Feb 24 2014, 12:13 AM
Shindog1961   No problem with the fuel pump mounted on the fire...   Feb 24 2014, 12:23 AM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th January 2025 - 11:56 AM
