73 fuel pump mounting question, It has been too long !!!!!!! |
David_S |
Jan 20 2008, 01:05 AM
Member Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region |
I started tinkering with my project again a few days ago, and am in the process of getting the engine bay back together. Only problem so far is I had to replace the right engine shelf, and I cant remember how the fuel pump mounts ! I attached a pic of the area where the Haynes manual shows it to be, but the pic in the manual isn't the greatest. Also in the pic, what mounts in the slotted J shaped bracked above the motor mount? It has been too long ago since I tore this thing apart and I screwed up and didn't take enough pictures !!!!!! TIA
Attached image(s) |
swl |
Jan 20 2008, 07:51 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Here is the 'as installed' position. The pump mounts by way of 2 rubber bushings - noise and vibration isolation. You can just see one at the top of the pump.
SirAndy |
Jan 20 2008, 11:48 AM
Resident German Group: Admin Posts: 41,961 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Here is the 'as installed' position. The pump mounts by way of 2 rubber bushings - noise and vibration isolation. You can just see one at the top of the pump. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 7th January 2025 - 12:18 PM |
