> 73 fuel pump mounting question, It has been too long !!!!!!!
David_S
post Jan 20 2008, 01:05 AM
I started tinkering with my project again a few days ago, and am in the process of getting the engine bay back together. Only problem so far is I had to replace the right engine shelf, and I cant remember how the fuel pump mounts ! I attached a pic of the area where the Haynes manual shows it to be, but the pic in the manual isn't the greatest. Also in the pic, what mounts in the slotted J shaped bracked above the motor mount? It has been too long ago since I tore this thing apart and I screwed up and didn't take enough pictures !!!!!! TIA
Cevan
post Jan 20 2008, 06:29 PM
Why not relocate the pump to the front?
ClayPerrine
post Jan 20 2008, 09:24 PM
QUOTE(Cevan @ Jan 20 2008, 06:29 PM) *
You are better off relocating the pump up front. That way you don't get the vapor lock problem. It will vapor lock, because the hot air dump from the heat exchangers points right at it.
post Jan 21 2008, 10:37 AM
Resident German
QUOTE(ClayPerrine @ Jan 20 2008, 07:24 PM) *
huh? (IMG:style_emoticons/default/confused24.gif)
i ran my '70 1.7L for 6 years with the pump in the stock location. never had a single problem with vapor lock. not even on the 110 deg. central valley drives ...
(IMG:style_emoticons/default/confused24.gif) Andy
David_S   73 fuel pump mounting question   Jan 20 2008, 01:05 AM
cwpeden   I replaced mine and didnt know either, this is wha...   Jan 20 2008, 02:33 AM
cwpeden   close up   Jan 20 2008, 02:36 AM
swl   Here is the 'as installed' position. The ...   Jan 20 2008, 07:51 AM
SirAndy   Here is the 'as installed' position. The...   Jan 20 2008, 11:48 AM
Cevan   Why not relocate the pump to the front?   Jan 20 2008, 06:29 PM
ClayPerrine   Why not relocate the pump to the front? :agree:...   Jan 20 2008, 09:24 PM
David_S   Why not relocate the pump to the front? :agree...   Jan 20 2008, 11:12 PM
SirAndy   Why not relocate the pump to the front? :agree...   Jan 21 2008, 10:37 AM
Phoenix914   I just replaced the mounts on my '73 because o...   Jan 21 2008, 12:02 PM
ConeDodger   In a properly maintained car you should not experi...   Jan 21 2008, 12:53 PM
SirAndy   At the pressure in an EFI system vapor lock shoul...   Jan 21 2008, 12:59 PM
KELTY360   In a properly maintained car you should not exper...   Jan 27 2008, 01:11 PM
stephestrad   In a properly maintained car you should not exper...   Jan 8 2014, 10:24 AM
Dtjaden   In 1973 I had a new 914. I was in Minnesota at tha...   Feb 24 2014, 09:47 AM
KELTY360   In 1973 I had a new 914. I was in Minnesota at th...   Feb 24 2014, 10:34 AM
swl   I suspect that the original engineers located the ...   Jan 22 2008, 11:42 AM
David_S   So ....going by the pic that SWL posted .....the f...   Jan 27 2008, 11:14 AM
swl   definitely not the engine tin. it stays with the ...   Jan 27 2008, 11:29 AM
David_S   SWL ......The small hole in my pic is about 1/4...   Jan 27 2008, 11:39 AM
swl   My pump is not installed at the moment - would you...   Jan 27 2008, 11:46 AM
swl   hmm. on your pic there are a couple of light spot...   Jan 27 2008, 11:50 AM
David_S   A pic would be wonderful!!!! I d...   Jan 27 2008, 11:56 AM
swl   just had a quicklook. I tried to grab a pic but I...   Jan 27 2008, 12:20 PM
David_S   SWL ...not a problem. I know what hibernation mode...   Jan 27 2008, 12:27 PM
swl   Here is the (shitty) pic of the mounts. I'm ...   Jan 27 2008, 12:48 PM
JawjaPorsche   I moved my pump to firewall twenty years ago and h...   Jan 8 2014, 10:44 AM
914_teener   :agree: I moved mine exactly as it appears above...   Jan 8 2014, 11:14 PM
stephestrad   Thanks to you both for the feedback and the locati...   Jan 9 2014, 12:33 AM
Shindog1961   I have heard that this pump location requires you ...   Feb 23 2014, 11:58 PM
914_teener   No problem with the fuel pump mounted on the firew...   Feb 24 2014, 12:13 AM
Shindog1961   No problem with the fuel pump mounted on the fire...   Feb 24 2014, 12:23 AM
19 User(s) are reading this topic (19 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th January 2025 - 12:15 PM
