brer |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None ![]() |
I'm working on a head program for guy here in SD. He had a similar problem I believe a member here had, and that was his chambers were too small for his 2056cc engine. (edited, he's using a 71mm crank and 96mm slugs)
Facing large barrel shimming, which he didn't want, I worked this up for him. perfect 60cc chambers, his non 2.0L heads will now install with a .045 shim , he has a zero deck, giving (I believe) a 8.5:1 compression ratio. This method of modifying heads results in perfectly matched chambers (and ports for him), so when he gets them back they will technically be blueprinted to within .001". not a 2.0L head granted, but thats sometin else and this is within his budget. Attached image(s) ![]() |
2-OH! |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 ![]() |
brer:
With that much meat removed, and the history of cracking around the spark plug holes, how do you think that configuration will hold up...Particularly if you open up the valve sizes... Also, will that much removed, how will it effect the valve/rocker geometry...It would appear that the valve stems will clear the other side of the guide by quite a bit more... 2-OH! |
Lo-Fi Version | Time is now: 29th June 2024 - 09:52 AM |
