73 fuel pump mounting question, It has been too long !!!!!!! |
David_S |
Jan 20 2008, 01:05 AM
Member Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region |
I started tinkering with my project again a few days ago, and am in the process of getting the engine bay back together. Only problem so far is I had to replace the right engine shelf, and I cant remember how the fuel pump mounts ! I attached a pic of the area where the Haynes manual shows it to be, but the pic in the manual isn't the greatest. Also in the pic, what mounts in the slotted J shaped bracked above the motor mount? It has been too long ago since I tore this thing apart and I screwed up and didn't take enough pictures !!!!!! TIA
Attached image(s) |
swl |
Jan 27 2008, 12:20 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
just had a quicklook. I tried to grab a pic but I was shooting in the dark and they are pretty shitty. I'll have to try again after I break out the trouble light (I'm in hibernation mode up here in the cold cruel north). Looks like Pelican will send you the rubber mounts.
http://www.pelicanparts.com/catalog/shopca..._pg3.htm#item11 901-501-864-00-OEM |
Lo-Fi Version | Time is now: 7th January 2025 - 12:06 PM |
