mattp |
Member ![]() ![]() Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 ![]() |
when cold I get a massive shudder in first gear when starting out. Anyone have any ideas? after its warm it get slightly less and no shudder in other gears?
thanks, matt |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,734 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
An easy way to check the engine mounts is to open the engine bay, put the emergency brake on, and have someone watch the engine as you slowly let out the clutch. If you can see the engine raise up alot, then the mounts are bad.
Lo-Fi Version | Time is now: 24th June 2024 - 11:59 PM |
