pete914 |
Member ![]() ![]() Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 ![]() |
So,
I'm running a 1.8L stock Vacuum advance dizzy with single weber (i know...not ideal) and as I've learned the advance curve is wrong for this setup and I have pretty bad lag now before 3000rpm. I swear the engine is running hotter now. Is it because the timing is too retarded in the lower rpm range? does that affect engine temperature? Anyone running a similiar setup with a suggestion as to where to set my timing to get better performance? I don't rev it up much past 4500 Oh, and I just ordered a a centrifugal advance dizzy, if someone is using one of those with a single carb and is having luck, please tell me your settings. Thanks. |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
Timing too HIGH for a given RPM range will definitely make hotter running temps in that range. Timing too retarded? IDK, maybe...
Lo-Fi Version | Time is now: 26th June 2024 - 12:09 PM |
