Wes V |
Member ![]() ![]() Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 ![]() |
Without worring about axles or attaching to the transmission, the question is;
If I install 71 911 hubs and stub axles on my 914, can I bolt the 944 CV unit to the stub axle? Wes |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
(IMG:style_emoticons/default/drooley.gif) I think I want to do that (IMG:style_emoticons/default/biggrin.gif)
Wes V |
Wow, I didn't expect to have "do a search" thrown at me that fast!
I did search and a lot of reading of what I found. I can't measure them due to the fact that I don't have them. What I'm wondering is if the hubs and stub axles in the following ad will work with the 944 CV's. 914world ad I'm trying to avoid talking about the CV at the transmission due to my planing on using a Passat transmission. Wes |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,270 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Wow, I didn't expect to have "do a search" thrown at me that fast! I did search and a lot of reading of what I found. I can't measure them due to the fact that I don't have them. What I'm wondering is if the hubs and stub axles in the following ad will work with the 944 CV's. 914world ad I'm trying to avoid talking about the CV at the transmission due to my planing on using a Passat transmission. Wes The hubs will work. The stub axles will not. You will need 944 stub axles, and get either a spacer, or cut down the hubs in a lathe to remove the same amount of material as the shoulder on the 944 stub axle. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,191 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
The hubs will work. The stub axles will not. You will need 944 stub axles say what? (IMG:style_emoticons/default/confused24.gif) i'm using 911 stub axles. they bolt right onto the 944 CV and fit into the 914 wheel bearing without any spacers ... (IMG:style_emoticons/default/bye1.gif) Andy |
Wes V |
I get the impression that to be able to bolt the 944 CV to the 911 stub axle, the stub axle has to be from a 75 to 89. My question on "model specific" has to deal with if it's an SC or not (or if there is any difference during those years)
I believe that the earlier stub axle has a different bolt spacing for the CV. Wes |
SirAndy |
My question on "model specific" has to deal with if it's an SC or not (or if there is any difference during those years) i'm not sure if it was model specific or across the board, but there certainly were different types of CVs over the years. i actually took a old 100mm 944CV and went to EASY (salvage yard) and looked for 911 stub axles and output flanges that matched the size and bolt pattern ... that's how i came up with the year range that i posted above. as long as the stub axle and output flanges are 100mm 6 bolt, they should work just fine. the hub has to be from a early 911 to fit the 914 wheel bearing and you need to make sure the stub axle has the same spline as the hub ... oh, and the output flange has to be coarse spline! i should have written down the part numbers ... (IMG:style_emoticons/default/rolleyes.gif) Andy |
Wes V |
Thanks to all, but one last (dumb ass) question;
When refering to 100mm, is this the bolt circle diameter, measured from the center of one bolt, to the center of the bolt directly across from it? Wes |
Lo-Fi Version | Time is now: 20th April 2025 - 06:29 AM |
