> Front suspenion A-arm refurm, Step-by-step
racunniff
post Feb 9 2008, 09:55 PM
volt914
My car had the most annoying popping / grinding sound coming from the passenger's side front A-arm. It got to the point that I almost did not want to drive the car any more. So, I decided to do something about it. Once I had diagnosed that it was the A-arm bearings causing the sound, I went to the Pelican and ordered this part (part number 99-3014-340-M230):
You'll need the following tools:
  1. Sockets - 11mm, 13mm, 17mm, 19mm
  2. Allen wrench - 8mm
  3. A BFH - "Big Friendly Hammer"
  4. Rubber mallet
  5. Breaker bar, pry bars, chisels, heat source, etc.
  6. Some grease (I used some white lithium grease)
I jacked the car up, and removed the wheel, so I could access the suspension:
Here is what the A-arm looked like at the begnining of this whole process:
First step in removing the A-arm is to remove the torsion bar adjusting screw (using an 11mm socket) and then pry the adjusting arm off the torsion bar (I used an Allen wrench as a lever to push it from behind):
Next is to remove the tapered pin from the ball joint. You back the nut off so it's clear of the threads (using a 13mm socket) and then you *carefully* strike it with a hammer - here is my BFH about to strike the nut (which has been soaking for a bit in penetrating oil). You have to hit it pretty hard to loosen it, but eventually, it will pop forward:
Once you get the initial "pop" you'll need to remove the nut and then use another bolt or something as a drift to push the pin far enough out so you can get at it with vice grips or something.
Coming soon, Part II
daveyboybadion
post Feb 10 2008, 12:12 AM
Thanks for a very informative post. From your avatar can we infer that your 914 has been electrified? If so could you post the details?...daveyboy
racunniff
post Feb 10 2008, 08:24 AM
volt914
QUOTE(daveyboybadion @ Feb 10 2008, 12:12 AM) *
Indeed - see my blog for all the gory details. In short - 144V system AC motor with regenerative braking, top speed probably 90-ish (never taken it there), range (in the summer) roughly 100 miles.
racunniff   Front suspenion A-arm refurm   Feb 9 2008, 09:55 PM
racunniff   Part II Next, you need to pop the ball joint out ...   Feb 9 2008, 10:03 PM
racunniff   Part III The Haynes book says "push the con...   Feb 9 2008, 10:13 PM
racunniff   Part IV With the rear bushing off, I found more r...   Feb 9 2008, 10:22 PM
racunniff   Part V And now, for the whole point of this exer...   Feb 9 2008, 10:31 PM
racunniff   Part VI As the Haynes manual says - installation ...   Feb 9 2008, 10:44 PM
daveyboybadion   Thanks for a very informative post. From your avat...   Feb 10 2008, 12:12 AM
racunniff   Thanks for a very informative post. From your ava...   Feb 10 2008, 08:24 AM
Eric_Shea   It looks as though this is the second go-round on ...   Feb 10 2008, 08:36 AM
crash914   OK, since no one else brought it up... VOte for c...   Feb 10 2008, 08:49 AM
TeenerTim   I did this exact same job yesterday. There is no n...   Feb 10 2008, 08:56 AM
rhodyguy   not to argue the point, but that 47 ft lbs on the ...   Feb 10 2008, 09:35 AM
r_towle   You need a front cap on the torsion tube to retain...   Feb 10 2008, 10:30 AM
rhodyguy   the little felt ring gasket at the rear too. k   Feb 10 2008, 10:36 AM
racunniff   the little felt ring gasket at the rear too. k ...   Feb 10 2008, 10:39 AM
rhodyguy   did you grease the length of the torsion bar? that...   Feb 10 2008, 10:52 AM
racunniff   did you grease the length of the torsion bar? tha...   Feb 10 2008, 06:42 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 07:51 PM
