> Back PAD Compresed Carboard Restoration, Has anyone done this.
xperu
post Oct 10 2009, 02:59 PM
TEXAS
Just looking for advice and maybe some pictures of restoration of backpad. Thanks Mike
zonedoubt
post Oct 10 2009, 03:21 PM
Canadian Member
I had to fix mine in a few spots where the pressboard was cracked. I used some thick cardboard as a patch (inside of binder covers), wood glue, and some clamps. Turned out not bad. You don't see it anyways. (IMG:style_emoticons/default/smile.gif)
benalishhero
post Oct 10 2009, 03:47 PM
QUOTE(zonedoubt @ Oct 10 2009, 05:21 PM) *
I used the same technique with 2-part epoxy. I was able to straighten the water damaged lower edge and reattatch the vinyl at the same time. As Zone already stated, you don't see it anyway.
Joe Owensby
post Oct 11 2009, 06:45 PM
JoeO
I straightened mine out, added additional cardboard where it had disentegrated. I then put a layer of fiberglass on both sides, overlapping the old and the new. Then covered it up with new backpad material.
xperu
post Oct 12 2009, 05:49 AM
TEXAS
QUOTE(Joe Owensby @ Oct 11 2009, 07:45 PM) *
Thanks guys, I will use one of these options, while I'm putting the last trim peices together and finishing the interior, this is the last repair job. Thanks Mike
johannes
post Oct 12 2009, 06:06 AM
Club Porsche 914 France President
Region Association: France
If you watch the classic threads you will see my door paner restoration thread. I restored the cardboard panel with white wood glue. You can also change the shape using a steam iron. http://www.914world.com/bbs2/index.php?showtopic=54608
morph
post Oct 12 2009, 09:17 AM
quality parts builder
We used to restore factory ones with fiberglass or epoxy.To flatten a area that is warped use 2x4s,or 6 with a release agent on them (clear shipping tape on the board so it wont stick to your back pad) and clamps.
james
IronHillRestorations
post Oct 12 2009, 11:15 AM
I. I. R. C.
I use wax paper as a "release agent". You can also spread your fg mat with resin on a piece of wax paper and then apply it to whatever you are 'glassing.
- Lo-Fi Version Time is now: 2nd January 2025 - 11:31 AM
