914/6 oil tank, Just thinking |
Oct 15 2009, 11:29 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I love the fill pipe...is that copper anodized? No. It's "mood" lighting ... (IMG:style_emoticons/default/biggrin.gif) The filler neck is aluminum, just like the rest of the tank. (IMG:style_emoticons/default/bye1.gif) Andy |
scotty |
Oct 16 2009, 10:08 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
No. It's "mood" lighting ... (IMG:style_emoticons/default/biggrin.gif) The filler neck is aluminum, just like the rest of the tank. (IMG:style_emoticons/default/bye1.gif) Andy Whoa...good thing you told me before I took her home! (IMG:style_emoticons/default/chair.gif) |
edwin |
Oct 17 2009, 03:12 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
not sure if anyone saw this
http://cgi.ebay.com.au/PORSCHE-914-6-ORIGI...=item3a53daf40f it isnt mine i just thought someone might be interested and it may be easy to miss as it is on the Aus Ebay. cheers edwin |
lotus_65 |
Oct 23 2009, 05:16 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
i know of a "doesn't leak" 911 tank for $50.
good deal? |
SLITS |
Oct 23 2009, 08:10 AM
Mark Henry |
Oct 23 2009, 08:45 AM
Can us hack and modify peeps cut up a 911 tank and make a 914 tank out of it? I can borrow a 914 tank for a pattern.
(IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) |
Rav914 |
Oct 23 2009, 09:32 AM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
What someone should do, someone with the skills, is make one. Document the process, publish the templates, list materials, take pictures, and post here.
Instant classic. Hero status. |
brant |
Oct 23 2009, 10:45 AM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
What someone should do, someone with the skills, is make one. Document the process, publish the templates, list materials, take pictures, and post here. Instant classic. Hero status. its still a crap load of work and not cheap I did it.. but probably still have 100 -150 of materials and parts into it. I used aluminum and tig'd the thing with AN fittings welded on its tough.. probably the reason they are pricey$$$ |
Mark Henry |
Oct 23 2009, 03:27 PM
Wasn't the originals just steel? Heck if it came down to it parker push-loc hose fittings would be fine for me.
I've seen some prices for the factory hoses. (IMG:style_emoticons/default/blink.gif) |
Oct 23 2009, 04:58 PM
Custom Member Group: Members Posts: 24,661 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Wasn't the originals just steel? Heck if it came down to it parker push-loc hose fittings would be fine for me. I've seen some prices for the factory hoses. (IMG:style_emoticons/default/blink.gif) I suspect, though not for sure, that the fittings on a 911 tank are the same as the fittings on a 914 tank. I am leaning towards getting a 911 tank and punting from that point. If I have the fittings, I can get the proper shape with some foam and make the thing out of steel. Rich |
brant |
Oct 23 2009, 05:26 PM
Rich,
it should work.. but depending upon what you use for oil lines you may or may not want to use the 911 fittings.. the tank fittings are metric if you use stock 914/6 oil lines than they will work fine most aftermarket lines are not metric they are often AN and if that is the case then you have to come up with metric to AN conversion fittings... we did this on my stock tank in order to use braided stainless oil lines. So depending upon your choice of oil lines, you may want to make the tank out of those fittings.... Thus the reason I made an aluminum tank and used aluminum AN fittings on it.. I intend to convert another car and use AN fittings/aftermarket lines on that car |
rfuerst911sc |
Oct 23 2009, 05:59 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I installed a Don Welch tank in my GT clone and that thing is a piece of art. Very well made. However I did convert both fittings to AN so I could run braided hose. Not that braided hose is cheap (IMG:style_emoticons/default/dry.gif) . I used -16AN from the tank to the engine cooler and -12AN from the engine to thermostat and then to front mounted cooler. If someone could make a tank maybe not quite as nice as Don's and maybe just a little cruder they could probably sell a few. But the market is not too big. I'm glad I got one when they were still available, as a matter of fact I got the tank,oil filter console and the filler neck with cap for $750.00 on special. I now realize how good a deal I got (IMG:style_emoticons/default/biggrin.gif) .
Dr Evil |
Oct 23 2009, 08:28 PM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
The AUS one relisted for $500 on ebay.
greenie |
Oct 23 2009, 09:02 PM
Senior Member Group: Members Posts: 873 Joined: 26-October 04 From: Trinidad Member No.: 3,013 Region Association: Pacific Northwest |
Not an easy item to obtain or build ..good luck.
Keep looking you'll find one. |
brant |
Oct 24 2009, 08:15 AM
photobucket ate my pictures..
but i finally found these tucked away: my template and the internal baffling Attached thumbnail(s) |
brant |
Oct 24 2009, 08:17 AM
these pictures were taken before welding was finished.
some of the seems are only tacked Attached thumbnail(s) |
Mark Henry |
Oct 24 2009, 04:35 PM
Thanks brant! any more pics?
If it was mild steel it wouldn't be too hard for me! What about repairing a rusty tank? I know were I can get one cheap. |
brant |
Oct 25 2009, 09:08 AM
a couple more pictures, but they don't show anything more really:
mild steel would be fine just use steel fittings it helps a ton to have access to a big break I did this tank in my votec welding class, and they had a number of helpful tools around that shop. An old style radiator shop would be a good place to start with a rusty tank I would think it could be easily brazed or repaired clean it well with a wire brush to expose all of the rusty areas Attached thumbnail(s) |
brant |
Oct 25 2009, 09:09 AM
and:
Mark Henry |
Oct 26 2009, 09:46 PM
Is a 914-6 tank and the tank from a -'83 930 turbo the same or close?
Lo-Fi Version | Time is now: 27th December 2024 - 04:31 AM |
