> New Rubber?, I need to get new tires ASAP
Black&White
post Oct 26 2009, 07:47 PM
Hello everyone I have a few more qustion?
1) Can I fit 205 50 r15 with stock fenders with stock wheels?
2) How will they mess up my speedo? Its starting to get a little wet up here and my tires are slick.
VaccaRabite
post Oct 26 2009, 08:41 PM
En Garde!
Probably. I have 205 55 r15 on mine. They are close, but no pulling was required. Your speedo is going to lie to you, though, with the 50s.
Each of these cars was built a little different (and beat up a little different over the past 30 years.) 205 is about the biggest you can usually go w/o rolling the fender, and I don't think you can get them to work with 60+ sidewalls.
Zach
burton73
post Oct 26 2009, 08:55 PM
burton73
I have 205/50-15 on my car will no rubbing and no pulling of the body by me. This is a 76 car.
BobAttached Image
Black&White
post Oct 26 2009, 08:58 PM
QUOTE(Vacca Rabite @ Oct 26 2009, 07:41 PM) *
Zach
Thanks I like to redo the fenders at some point but right this min I need rubber first... I trying to do the needs before the wants but its so hard..
Brad
underthetire
post Oct 26 2009, 09:01 PM
I have 205/50/16 on mine. Its close in the rear but they fit.
post Oct 26 2009, 09:06 PM
Resident German
QUOTE(Black&White @ Oct 26 2009, 05:47 PM) *
http://www.914world.com/specs/tirecalc.php
(IMG:style_emoticons/default/bye1.gif) Andy
messix
post Oct 26 2009, 10:25 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
good to see another north ender on here.
i live over around silverfirs area, and there are a bunch more us us in the area too.
we'll have to have a teener tuesday to welcome you to the madness.
ClayPerrine
post Oct 26 2009, 10:45 PM
The Wife's stock 914 has 205/50-15 Falken Azenias on it. They fit on stock 15x5.5 rims without any rubbing and they stick like crazy.
Speedo reads about 7 MPH fast.
jcwells
post Oct 26 2009, 10:52 PM
QUOTE(Black&White @ Oct 26 2009, 06:47 PM) *
I'm running 205/50 r15 BF Goodrich g-force Sports on my stock 15x5.5 Fuchs, with stock fenders. The tires pooch out a bit on the narrow wheel, but they handle well, even on the autocross pad. The g-force sport all season would be a decent winter alternative.
The calculators suggest that your speedo might be off by about 10% (54 mph actual at 60 mph indicated). I need to take the GPS for a spin with me sometime to verify this.
SGB
post Oct 27 2009, 11:13 PM
just visiting
QUOTE(jcwells @ Oct 26 2009, 11:52 PM) *
Do you think you could squeeze another 5 mm on each side in the back? There are 215/50-15 BFG g-force tires at tire rack. I want to put these on in a big way, with 205s in the front. Can you squeeze your little finger in there- not only at the fender but on the inside where there is a panel between the spring and tire? I would hate to order them and have to return- if you can. I've read all the specs and measurements and it MIGHT fit.
jcwells
post Oct 28 2009, 09:12 AM
QUOTE(SGB @ Oct 27 2009, 11:13 PM) *
I can easily get a finger in between the tire and fender in the rear. I also have clearance to the inside. There is a small lip on the inside of the fender that could be rolled over to give some more clearance. My concern would be squeezing some more tire onto the 5.5" Fuchs'. Do you need the extra meat in the back to hook up some big horsepower? I smoke my clutch before I can smoke the tires with my 125hp 2 litre.
- Lo-Fi Version Time is now: 26th December 2024 - 11:56 AM
