Socalandy |
Its got to be Yellow!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California ![]() ![]() |
thats the plan. I have a soda/media blaster for that. Now where's my cup gun (IMG:style_emoticons/default/unsure.gif)
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
Looking good Andy! Almost ready to blast! (IMG:style_emoticons/default/biggrin.gif)
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,171 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
You guys tell me but Im thinking so Is that where the factory mounted the washer pump? Nope. That pump is neither factory nor in the factory location ... The /6 washer pump looks like a 911 pump of the time and is mounted on those little rubber insulators you see in the same pic, next to that hacked rectangular "slot" ... (IMG:style_emoticons/default/shades.gif) Andy |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Attached image(s) ![]() |
Socalandy |
Thanks for the info. Now I can fill those screw holes along with that slot. It had nothing passing thru it and was covered with duct tape. What are people thinking when they do this stuff? (IMG:style_emoticons/default/chair.gif)
Socalandy |
so here is my oil tank and I'm ready to take it to be hot tanked and cleaned out. So for those of you that have been thru the process whats the best aproach ? I plan on sending it out to have it copper plated again before the re-paint.
It has a little surface rust but not anything deep and the inside still has a nice coating of oil so I think I'm OK in that dept. Thanks, Attached image(s) ![]() |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,154 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
When I take it all apart I will get some photos and see if it looks like an add on. It does look like a stock sway bar like the one I installed on the -4 You are a hero to save this car. Yes the sway bar is h&h aftermarket and one can tell by the inner fender well bracket that it was installed after the car left the factory. |
Socalandy |
Well these were going to go on my 72 -4 but now they will sit waiting to go on the -6 car.
Thanks again to Al Reed!! (IMG:style_emoticons/default/aktion035.gif) Attached image(s) ![]() ![]() |
Sleepin |
ohhh....that gives me a weird tingly feeling on the inside! (IMG:style_emoticons/default/drooley.gif)
I was asked to post pictures of what I have to work with. More when it gets moved into the garage. Time to get dirty (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) That car looks familiar! I'm pretty sure i have seen this one a few years back ... (IMG:style_emoticons/default/idea.gif) Andy Doh! I'm with stupid ... (IMG:style_emoticons/default/givemebeer.gif) No wonder the yard looked familiar. I actually had my dirty little hands all over that car a few years back. Glad to see someone finally had the guts to restore it! (IMG:style_emoticons/default/smilie_pokal.gif) Andy |
Socalandy |
Scheel seats are being redone finally and I've always wanted to know what was under the skin and foam (IMG:style_emoticons/default/WTF.gif)
Socalandy |
(IMG:style_emoticons/default/welder.gif) hand made frames, Time to blast and paint them. More pics in the next few days
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,104 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Now I do not have to take my Scheels apart to see what they look like. My bottoms have the webbing missing on the bottom too. Somebody used bunge cord and a piece of carpet as replacements.
Socalandy |
the webbing was there, just been removed so I could sand blast the frames. they were worn out for sure but will be like new soon
Socalandy |
Blasted and painted, Pannels are coming together (IMG:style_emoticons/default/biggrin.gif)
Socalandy |
Socalandy |
Socalandy |
proto31 |
Member ![]() ![]() Group: Members Posts: 413 Joined: 2-February 06 From: Costa Mesa, CA. Member No.: 5,515 Region Association: None ![]() ![]() |
Andy, did you sand blast and paint the frame or did your upholsterer do it? Is he going to reuse most of the foam or is he using all new foam? Looks like they're going to turn out really nicely!
Dan |
Socalandy |
I went by yesterday for some pictures and saw the suface rust. took them home for the blasting and paint and returned them today. They would have done a quick sanding and painted them but wanted to get it all off. They are shaping all new foam to match the original pieces, everything will be new but the frames.
Lo-Fi Version | Time is now: 3rd April 2025 - 01:12 AM |
