My 914-6 project, That's a rap, Thanks Everyone!!! |
Socalandy |
Nov 8 2009, 12:24 AM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
(IMG:style_emoticons/default/piratenanner.gif) Well I placed a few orders for the car and they are coming in (IMG:style_emoticons/default/aktion035.gif)
New set of grills Attached image(s) |
JmuRiz |
Aug 5 2013, 02:14 PM
914 Guru Group: Members Posts: 5,440 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Socalandy |
Aug 5 2013, 03:12 PM
Is this car going to a museum when finished? Auction? Way too nice to drive! (IMG:style_emoticons/default/shades.gif) Thanks for the great compliments!!! I plan on driving it a lot and fully enjoying it for many years and 914 events. (IMG:style_emoticons/default/driving.gif) The VHT header paint held up great on my 72 rotors and keeps the rust away. |
Socalandy |
Aug 10 2013, 12:42 AM
More bling from PMB installed!!! Got out to the garage after work and set the back spacing to center the calipers. Should have all the brakes done tomorrow and bleed the system (IMG:style_emoticons/default/biggrin.gif)
Attached thumbnail(s) |
ConeDodger |
Aug 10 2013, 07:43 AM
Apex killer! Group: Members Posts: 23,628 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Ooo! Ahh! (IMG:style_emoticons/default/evilgrin.gif)
Cairo94507 |
Aug 10 2013, 08:00 AM
Michael Group: Members Posts: 9,850 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Andy- Very nice. Did you grind down the trailing arm reinforcements for clearance for the GT calipers or did you space the rotor outward? My car will stay narrow-bodied so I can't afford to space the rotor outward.
Socalandy |
Aug 10 2013, 09:53 AM
Andy- Very nice. Did you grind down the trailing arm reinforcements for clearance for the GT calipers or did you space the rotor outward? My car will stay narrow-bodied so I can't afford to space the rotor outward. Thanks, I opted for the tube style reinforcement adding the two you see in the photo so I think your referring to the stock brake adjustment tube in the swing arm? I did grind the outside tube down per Eric Shea's recom. to clearance the caliper from the swing arm. It cleared (IMG:style_emoticons/default/piratenanner.gif) |
SLITS |
Aug 10 2013, 09:59 AM
Andy, I don't remember if your rear hubs are "hub centric" or not. If "hub centric", a 5 mm spacer under the caliper ears is necessary to center the rotor. They don't look "hub centric".
Forget it ... it's a stock six now that the grey cells have kicked in! |
Socalandy |
Aug 10 2013, 06:08 PM
No problem Ron, I installed my calipers, lines,spacers and bolted the wheel on only to relize the pads didnt go in... (IMG:style_emoticons/default/blink.gif) But i did get all four corners done today (IMG:style_emoticons/default/biggrin.gif)
ConeDodger |
Aug 10 2013, 06:27 PM
Bleeder on the bottom?
ConeDodger |
Aug 10 2013, 06:32 PM
Pretty sure the bleeder and line go on the inside. If the bleeder isn't on the top, how can the air get out?
Socalandy |
Aug 10 2013, 09:47 PM
Yeah, this was the first side and right after I realized the dust shields were not correct for S calipers and took the rotors off and deleted the shields. I did notice it was the drivers side and both bleeders are on top.
I had a few steps backwards today but got it done less the proportioning valve and bleeding Attached thumbnail(s) |
badm |
Aug 11 2013, 08:25 AM
Member Group: Members Posts: 213 Joined: 10-May 09 From: Cape Cod Taxachusetts Member No.: 10,350 Region Association: North East States |
Wow! I have been away from the World for the last year and just spent the last 20 min on your thread. Having gone through some of the same process it's amazing to see it in pictures. Your quality of work is amazing and trust me in the end it will all be worth the trouble and time. My GT took 5 years and I never thought it wold be done. Badm
McMark |
Aug 11 2013, 09:26 AM
Lookin good! (IMG:style_emoticons/default/thumb3d.gif)
You don't need clamps on the reservoir blue lines. No pressure there. |
pete000 |
Aug 11 2013, 10:59 AM
Aug 11 2013, 11:58 AM
914-6 GT in waiting Group: Members Posts: 19,332 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You don't need clamps on the reservoir blue lines. No pressure there. Did the 914's 6 and 4's come from the factory clamp less? Maybe overkill but maybe not a bad idea to insure the lines never come loose and drip fluid on the paint. |
Socalandy |
Aug 11 2013, 06:12 PM
You don't need clamps on the reservoir blue lines. No pressure there. Did the 914's 6 and 4's come from the factory clamp less? This is the original line and it had claps on each hose? Not to say a PO had done it but it's the way it was when I got the car. (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
bigkensteele |
Aug 11 2013, 07:06 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I don't disagree with Mark, but nobody ever lost their braking when they really needed it by clamping a hose that didn't technically need to be clamped. Mine appear to be clamped from the factory as well.
bigkensteele |
Aug 11 2013, 08:07 PM
Doh! Double post.
Sleepin |
Aug 20 2013, 04:00 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Nice Andy! Any Updates?
Socalandy |
Aug 21 2013, 09:37 AM
Nice Andy! Any Updates? Sadly No (IMG:style_emoticons/default/sad.gif) Work has been crazy and the car wont be ready for RRC this year. I'm not going to rush it and then make that drive to CO. my shake down test. I'll still be in the garage this weekend getting things done!!! |
Lo-Fi Version | Time is now: 23rd June 2024 - 12:30 PM |
