RON S. |
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States ![]() |
Out of the blue the wife gave me permission to spend a bunch of cash on the teener. I have the slightest idea what I did right or what she did wrong. I have to check out the finances but I'd like to do a 6 conversion. I know diddly about the flat 6. I need some help. Parts list. Oil tank. Oil filter console. Oil filter. Oil filler neck. Dipstick. Oil filler cap. Oil filter adapter rubber boot and snap ring. Suction line from tank to coupler. Oil line coupler. Oil line from coupler to oil cooler. Engine mounted oil cooler (modified or stock.. stock is more expensive) Oil scavenge line from engine to tank (stock hard metal line is hard to find. Easy to get the 911 rubber line to replace it.) Engine mount. (Recommend the Rich Johnson mount.) Engine tin set. Early 911 Flywheel, or aftermarket conversion flywheel. (To hook to 901 transmission) Heat exchangers or headers (headers are cheaper, but no heat for interior) 911 muffler. Either 40IDA3C Weber carbs and linkage or PMO Carbs and linkage. 914/6 throttle bellcrank, rod and cable bracket. plus 914/6 throttle cable. You also have to modify the engine wiring harness to hook it to the car, cut the holes for the oil tank, remove the stock 4 cylinder motor mounts, and weld in the six cylinder motor mounts. And if you are going to do this, you need to upgrade the brakes. I recommend the Boxster brake conversion. Unless you purchase some of the pricey billet hubs, this will more than likely require a 5 lug conversion. That means new wheels. See where this can add up???? Have cash, LOTS OF CASH. When you start down this rabbit hole, you'll be hard pressed to find out just how deep it goes. If you start spending money on expensive parts and then give up, you're going to have a large investment that you'll never recoup. 10-20k would not be hard to put into a conversion if done nicely and properly. throw in an engine rebuild, and that'll add another 7-10k. Don't be shocked at the numbers, just bear in mind that all of us has faced the same music. Ron |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,596 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
If you start down this rabbit hole, I suggest that you never total up the receipts. If you total them BEFORE you finish the six conversion, you will not finish it, ever. If you total it afterword, you will kick yourself every time you drive the car. I did a rough off the cuff estimate on what I spent on my car.... I could have a new GT3 for what I currently have in it, and I have not finished it. I still have lots to do. But the bottom line for me is that "I" built this car. Anyone with a healthy checkbook can go buy a GT3. There are a few people out there like me who can build a car like mine. And a new GT3 would be generic Porsche, and not an extension of my personality and desires. Bottom line, what do YOU want to do.... Forget all the financial advice, forget the work involved, do you want to BUILD a 914/6??????? It is not a logical thing, it is an emotional thing. You have to want to do this, and want it bad enough so that the cost and effort is irrelevant. |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,712 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
You have to want to do this, and want it bad enough so that the cost and effort is irrelevant. (IMG:style_emoticons/default/agree.gif) |
burton73 |
burton73 ![]() ![]() ![]() ![]() Group: Members Posts: 3,570 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
You have to want to do this, and want it bad enough so that the cost and effort is irrelevant. (IMG:style_emoticons/default/agree.gif) Larry has a nice 3.2 in the Classified for $5,000. I have a 2.5 SS that I am rebuilding that I will spend over $5,000 on machine work and parts and crab work. I would put the 3.2 in but it just would not be in character for my real 6. You could get brakes from Rich Johnston as well as motor mounts. You will need the 911 front end and a 911 e-break setup and 5 lug for the rear and tangerine has the E-break cable. Yes on the wheels of your desire. Bob |
TROJANMAN |
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None ![]() |
Parts list. Oil tank. Oil filter console. Oil filter. Oil filler neck. Dipstick. Oil filler cap. Oil filter adapter rubber boot and snap ring. Suction line from tank to coupler. Oil line coupler. Oil line from coupler to oil cooler. Engine mounted oil cooler (modified or stock.. stock is more expensive) Oil scavenge line from engine to tank (stock hard metal line is hard to find. Easy to get the 911 rubber line to replace it.) Engine mount. (Recommend the Rich Johnson mount.) Engine tin set. Early 911 Flywheel, or aftermarket conversion flywheel. (To hook to 901 transmission) Heat exchangers or headers (headers are cheaper, but no heat for interior) 911 muffler. Either 40IDA3C Weber carbs and linkage or PMO Carbs and linkage. 914/6 throttle bellcrank, rod and cable bracket. plus 914/6 throttle cable. You also have to modify the engine wiring harness to hook it to the car, cut the holes for the oil tank, remove the stock 4 cylinder motor mounts, and weld in the six cylinder motor mounts. And if you are going to do this, you need to upgrade the brakes. I recommend the Boxster brake conversion. Unless you purchase some of the pricey billet hubs, this will more than likely require a 5 lug conversion. That means new wheels. Or you could buy mine (IMG:style_emoticons/default/biggrin.gif) :trackfees: |
RON S. |
(IMG:style_emoticons/default/agree.gif) If you start down this rabbit hole, I suggest that you never total up the receipts. If you total them BEFORE you finish the six conversion, you will not finish it, ever. If you total it afterword, you will kick yourself every time you drive the car. I did a rough off the cuff estimate on what I spent on my car.... I could have a new GT3 for what I currently have in it, and I have not finished it. I still have lots to do. But the bottom line for me is that "I" built this car. Anyone with a healthy checkbook can go buy a GT3. There are a few people out there like me who can build a car like mine. And a new GT3 would be generic Porsche, and not an extension of my personality and desires. Bottom line, what do YOU want to do.... Forget all the financial advice, forget the work involved, do you want to BUILD a 914/6??????? It is not a logical thing, it is an emotional thing. You have to want to do this, and want it bad enough so that the cost and effort is irrelevant. (IMG:style_emoticons/default/agree.gif) Well said Clay!!! No one could have said it better. I got 11 years of effort in my ride, and am always finding another project on it to take it another step further. It does become an extension of ones personality. Ron |
jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
hey...I'm just up the road from you (in brookfield). I'm in the middle of my conversion. I've got all my parts and ready for reassembly (probably this spring). I got an 84 911 with 65k miles and used it as a donor and parted the rest. So, outside of my labor/time i'm at about a break even. If I would have just purchased everything outright I'd probably have about 10k into it. Parting out took a long time but basically bought all of my parts.
Kargeek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 ![]() |
Wow! Better strike while the iron is hot! What a gal! I bet she mows the lawn too? Tell her there should be more gals like her...can I have her talk to my wife and do some convincing? Be careful...Maybe it's a set up? |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
I don't want this to be another four vs six debate. I like them both. But when I dream about what the car will have when it's done, it's a six. The wife gave me permission so my dream is a bit closer to reality. She's pretty cool.
Anyhow, What I was really hoping for was some advice on engines. Similar to what Clay said in the second post. I like the small to medium cc screamers. Are there certain combo's that work the best? Anything I should stay away from? |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I would sell off what you have, combine that with the "Honey" Money, and buy either a Real 914-6 (HotRod or no) or an already completed -6 Conversion. If you do Due Diligence, you can buy alot of car right now. Plus you could drive it Now. (IMG:style_emoticons/default/driving.gif) T.C. I totally agree. (IMG:style_emoticons/default/agree.gif) Properly done, you will have a great car for less money and time....and you can spend more time with your Wife and take her to dinner instead of fixing your car. |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
good deal, man. then I'd listen to what clay said. he's one of the most knowledgeable 914'rs I know, and if I wanted to know how to do a -6 right, he'd be the first person I'd call.
sixgt |
Member ![]() ![]() Group: Members Posts: 70 Joined: 14-November 07 From: left coast Member No.: 8,337 ![]() |
I ran a 2.4 w/2.2S pistons and e cams. Match porting, webers, not much else. Plenty of torque on the street, was awesome for autoX. I had the original six, no flares with and 7" fuchs. At one autoX, I let the top time of the day driver (driving a highly modified no $ spared 911 with huge wheels & tires) take me for a fun run. With both of us in the car, he beat his top time of day by half a second. I eventually sold this car to a friend of mine who has raced it successfully in SCCA and PCA with many wins. Great combo, very reliable, streetable, not big $. You could add more cam but I was happy with the drivability of the "E" cams. hth
jmill |
The fun of the whole thing is building it. I've built several. I have a vision and then run with it. I lost my ass on all but one. That one was bought by the Pesi Cola Bottling Co. I got tired of selling them when I was done. This time I promised myself I'd buy a car that I loved (914). Then I would go nuts and build my dream car. I don't want someone elses car. I don't want to wreck an original 6 nor do I have the cash for one. I want to build the car I have. A rust free 73 Zambesi (always loved that color). It was bent up but I straightened it out and I only need a couple of pieces to complete it. I have a 911 front suspension. I'm going 5 lug. I'm halfway there already. As mentioned in the first post, I have the 911 performance handbook. I'm reading it now. I was just hoping to get some instant gratification from the knowledgeable 6 guys here. I guess I was looking for a recipe. Using this block, with these pistons and this cam, will give you this.
Like I said. I know nada about the 6. I was hoping for a quick education. |
ClayPerrine |
Here is what I would do if I were going to build a small motor..
Start with a sand cast aluminum case (68 or older). Get a 2.2S crank and rods. 2.7S pistons and cylinders. 2.7 S heads drilled for twin plug. Turbo oil pump. Do all the recommended case mods. 906 cams. MFI with either high butterfly or slide valve stacks. Twin plug distributor. It would look something like this...... ![]() What you get is a 2.5 short stroke screamer that wont pull down low, but will really come on strong when you get it on the cams..... |
jmill |
Thanks. That's what I'm looking for. I like carbs but MFI works for me too. It's spendy but I'm somewhat familiar with it. I had an Alfa with it.
736conver |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None ![]() |
hey...I'm just up the road from you (in brookfield). I'm in the middle of my conversion. I've got all my parts and ready for reassembly (probably this spring). I got an 84 911 with 65k miles and used it as a donor and parted the rest. So, outside of my labor/time i'm at about a break even. If I would have just purchased everything outright I'd probably have about 10k into it. Parting out took a long time but basically bought all of my parts. Jim you've been in the middle of that conversion for awhile now. What was that 4 years ago you were over here. (IMG:style_emoticons/default/biggrin.gif) |
ClayPerrine |
Thanks. That's what I'm looking for. I like carbs but MFI works for me too. It's spendy but I'm somewhat familiar with it. I had an Alfa with it. Alpha-Romeo MFI only has one throttle body, the 911 MFI has six. It is a whole nother animal when you have to get correlation done on all six throttle bodies. And I think I have one of two or 3 914s with MFI. Love it... Personally I think it is MUCH better than carbs. And if you want the high butterflies, then you are talking 2500.00 for just the stack setup. If you want the slide valves, well, they are unobtanium. So you better befriend a machinist who can make you a set. Good luck and keep us posted. |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,411 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
OK, Now I see that you are already committed to the Zambizi and have the suspension. Buy Larry's 3.2 and you a Big step forward. If you start a build on a motor, commit at least $10k. Larry's 3.2 will give you power and reliabilty. Have Dr Evil build your 901 and maybe have a spare
Have fun and thank your lucky stars that you have a wife like that. T.C. |
jim912928 |
Brian,
Yep...i had a few diversions over the years. Last time I saw you I had the 911 donor and the 4 was still in the car. But now I have ALL the parts, engine is out and sold, the 911 was totally parted out (that alone took a good year...won't do that again!) and sold off...I'm now rounding 3rd base and heading for home! |
I vote for a big /6. Moah power, yet reliable. And they come with all the perks of a modern FI system.
I get better fuel mileage in my 914 with the 3.6L than i get in my 2002 Jetta. (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/driving.gif) Andy |
Lo-Fi Version | Time is now: 1st July 2024 - 12:59 AM |
