dkos |
say, "RUST"! ![]() ![]() Group: Members Posts: 295 Joined: 1-December 04 From: Philadelphia, PA Member No.: 3,204 Region Association: None ![]() |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
I have a set of Tangerine Racing fuel lines for my /6 resto. But I'll tell you this; If the original fuel lines are still soft and pliable, you don't need to replace them. At least not at this time IMHO. Save your money right now for something else on the car and do the fuel lines later if you chose to do so. If they're hard and brittle, they will crack easily and should be replaced.
dkos |
I have a set of Tangerine Racing fuel lines for my /6 resto. But I'll tell you this; If the original fuel lines are still soft and pliable, you don't need to replace them. At least not at this time IMHO. Save your money right now for something else on the car and do the fuel lines later if you chose to do so. If they're hard and brittle, they will crack easily and should be replaced. Hard to tell what kind of condition they are in. What I can reach feels flexible and smooth. |
Gint |
Check the ends in the engine compartment. That's where they get hard and brittle. You can easily pull the rubber hose from the plastic lines and check them that way.
Lo-Fi Version | Time is now: 25th June 2024 - 09:35 PM |
