HELP. trouble starting 72 1.7L |
Spoke |
Dec 10 2009, 10:23 PM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Did you do all the tests listed?
Test 3 will test if you have voltage at the fuel pump. If the fuel pump relay is clicking (Test 2) then Test 3 will test for voltage at the fuel pump. PM me when you want to talk. Sounds like we're getting close. Test 1 proves that you have 12V to power the ECU. This is good. Test 2 proves that the ECU can power the relay. Test 3 proves that you have voltage at the fuel pump. Good thing about these relays is that they are the same unit and can be swapped like Rich said before. |
forzamotorsport9 |
Dec 10 2009, 11:51 PM
Newbie Group: Members Posts: 44 Joined: 2-November 09 From: Bettendorf Iowa Member No.: 11,001 Region Association: Upper MidWest |
Did you do all the tests listed? Test 3 will test if you have voltage at the fuel pump. If the fuel pump relay is clicking (Test 2) then Test 3 will test for voltage at the fuel pump. PM me when you want to talk. Sounds like we're getting close. Test 1 proves that you have 12V to power the ECU. This is good. Test 2 proves that the ECU can power the relay. Test 3 proves that you have voltage at the fuel pump. Good thing about these relays is that they are the same unit and can be swapped like Rich said before. i did test 1 and 2, both positive. ill pm you my phone number so you can guide me through test 3, im a little bit confused as to what to do. im making progress though, and learning a helluva a lot on the way. ill drink to that (IMG:style_emoticons/default/beer3.gif) |
forzamotorsport9 |
Dec 10 2009, 11:56 PM
what color wire is currently plugged into the fuel pump? Rich so, at the pump...what color is the wire. Rich ill check that tomorrow i forgot to tonight (IMG:style_emoticons/default/headbang.gif) |
silverteener |
Jan 1 2010, 02:38 PM
Member Group: Members Posts: 214 Joined: 9-August 05 From: East Moline, IL Member No.: 4,566 |
ok,
We're going to start working on this again. I've printed off this post so we can run thru all the tests. We my end up bringing Wills car to my house so we have all tools we need, and it would be easier for me! I hope to have the pump running this weekend (IMG:style_emoticons/default/beerchug.gif) |
silverteener |
Feb 27 2010, 05:53 PM
Well we finally got Will's car to my house. I just went thru Spokes tests and on 2d when I jumped the ground I could not hear the fuel pump relay clicking. I'm not sure where to go from here but I haven't looked into it yet. Gotta go get the little one at mema's and papa's!
Spoke |
Mar 1 2010, 11:39 AM
If you can't get the fuel pump relay to click with power on with 12V measured at Pin I to the ECU (ECU disconnected) and Pin III to the ECU connected to ground, then we need to look at the connections to the fuel pump relay and the relay itself.
Check the resistance of the fuel pump relay coil. Do this by turning ignition OFF, with ECU disconnected, set voltmeter to OHMS and measure resistance between Pin I and Pin III to the ECU. You should read the resistance of the coil which (a guess) should be about 10-50 ohms. If high impedance, we have a problem. To test the fuel pump relay, swap the power supply relay for the fuel pump relay, turn ignition on and measure 12V at Pin I to the ECU. If not 12V then something is wrong with the relay. If 12V, then the relay is ok. |
silverteener |
Mar 2 2010, 06:29 PM
thanks for the info Spoke. I'm in Atlanta right now but when I get home on Monday I will do the tests. thanks again.
Scott |
silverteener |
Mar 9 2010, 08:39 PM
Ok, I checked the resistance on the fuel pump relay coil and it read 72.5 ohms. I also checked and we have 12v at pin I with the ignition on.
And now I thought I heard a faint click when I turn the key on which may be the fuel pump relay clicking. or I'm hearing things and 2nd guessing myself! |
silverteener |
Mar 10 2010, 08:35 PM
Will was over tonight so we were able to try a couple more things. I confirmed there is power at the pump for 1.5 seconds but the pump won't run. I also switched out the ECU with another one I had and it still won't work. For some reason the fuel pump won't run. We also tried another fuel pump that I have and it won't run either. Any Suggestions??
Thanks Scott |
Spoke |
Mar 11 2010, 06:00 AM
Will was over tonight so we were able to try a couple more things. I confirmed there is power at the pump for 1.5 seconds but the pump won't run. I also switched out the ECU with another one I had and it still won't work. For some reason the fuel pump won't run. We also tried another fuel pump that I have and it won't run either. Any Suggestions?? Thanks Scott Just to confirm, the fuel pump has power as expected (1.5 sec) when the key is turned on but the pump isn't running at that time, correct? Or is it the pump runs for 1.5 sec when the key is turned on but it won't run when cranking the engine? |
silverteener |
Mar 11 2010, 08:09 AM
Will was over tonight so we were able to try a couple more things. I confirmed there is power at the pump for 1.5 seconds but the pump won't run. I also switched out the ECU with another one I had and it still won't work. For some reason the fuel pump won't run. We also tried another fuel pump that I have and it won't run either. Any Suggestions?? Thanks Scott Just to confirm, the fuel pump has power as expected (1.5 sec) when the key is turned on but the pump isn't running at that time, correct? Or is it the pump runs for 1.5 sec when the key is turned on but it won't run when cranking the engine? There is power as expected for 1.5 sec when the key is turned on but the pump isn't running at that time. I also plugged one of my pumps in and it won't work either (IMG:style_emoticons/default/confused24.gif) |
Mar 11 2010, 02:36 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Did you check the power and ground wires of the pump? Could be a ground problem...
--DD |
silverteener |
Mar 11 2010, 02:54 PM
I tested the plug for power but how do I check it for ground? I did clean and tighten the grounds next to the relay board and the transmission ground is also tight.
Thanks! |
silverteener |
Mar 11 2010, 08:25 PM
Well I believe I found the problem. both fuel pumps are junk. I found another pump and wired it up to the battery and it worked. I wired up my spare pump we were using and it wouldn't work (IMG:style_emoticons/default/confused24.gif) . All I need to do is plug the good one into Will's car and we can see if it will start. Hopefully there won't be too many other problems with it and he'll be (IMG:style_emoticons/default/driving.gif) in no time!
Lo-Fi Version | Time is now: 26th June 2024 - 04:13 AM |
