Late Model Access Panel For Fuel Pump Installed, Pictures of where I placed a late model panel in my 1970 |
kenshapiro2002 |
Nov 28 2009, 07:39 PM
Senior Member Group: Members Posts: 1,443 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Thought I'd throw up six shots (in three posts) of where, and how, I installed the fuel access panel form a late model (75/76) into the firewall between the front trunk and the fuel tank recess, in my 1970 914.
kenshapiro2002 |
Nov 28 2009, 07:40 PM
kenshapiro2002 |
Nov 28 2009, 07:42 PM
kenshapiro2002 |
Nov 28 2009, 07:43 PM
Prime and paint the edges and holes that you cut. |
tod914 |
Nov 28 2009, 07:44 PM
Very nice and professionally done Ken. Think you'll start a new trend now (IMG:style_emoticons/default/drunk.gif)
VaccaRabite |
Nov 28 2009, 08:15 PM
En Garde! Group: Admin Posts: 13,636 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Awesome. make sure you round off the metal you just cut with a grinder or a file. You don't want to slice a finger or fuel line on a sharp jaggie.
Zach |
kenshapiro2002 |
Nov 28 2009, 08:47 PM
Used a file on the edges right away. May even glues some caps or pieces of plastic tubing over the backs of the screw holes so the protruding sheet metal screws can't touch the fuel lines either.Really shouldn't be a problem, but may just do it to be extra careful.
Awesome. make sure you round off the metal you just cut with a grinder or a file. You don't want to slice a finger or fuel line on a sharp jaggie. Zach |
tod914 |
Nov 28 2009, 09:13 PM
Ken how about JB welding on some nuts on the back wall so you don't need the sheet metal screws? Think that would work?
kenshapiro2002 |
Nov 28 2009, 10:13 PM
VaccaRabite |
Nov 28 2009, 10:20 PM
Why?
Sheet metal screws work like a champ in this application, and have for 30+ years. And JB might not hold when torqued and vibrated against constantly. K.I.S.S. Zach |
kenshapiro2002 |
Nov 28 2009, 10:25 PM
Zach...I'd trust you 100% if it weren't for the ends of the mustache turning up like that..that Snidely Whiplash thing. If I promise to stay with the sheet metal screws will you promise not to tie my car to the railroad tracks?
Why? Sheet metal screws work like a champ in this application, and have for 30+ years. And JB might not hold when torqued and vibrated against constantly. K.I.S.S. Zach |
MrKona |
Nov 28 2009, 10:32 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
Consider Rivet nuts. You've already got the hole locations started, you could make them big enough to install the rivets. Then you could use machine screws to attach the mount to the firewall. (IMG:style_emoticons/default/white914.jpg)
jmill |
Nov 28 2009, 10:33 PM
I'd go with a nut clip. Cheap and easy without the sharp point next to your fuel line. You don't need the nut cert (riv-nuts) tool either. I've had them spin on me.
kenshapiro2002 |
Nov 29 2009, 06:09 AM
JFJ914 |
Nov 29 2009, 01:07 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
The factory used sheet metal screws. Why get fancy?
Drums66 |
Nov 29 2009, 01:19 PM
Zach...I'd trust you 100% if it weren't for the ends of the mustache turning up like that..that Snidely Whiplash thing. Why. K.I.S.S. Zach (IMG:style_emoticons/default/biggrin.gif) Maybe a rubber moulding edge around the access door? other than that tip, looks great!! (good humor man) (IMG:style_emoticons/default/biggrin.gif) |
IronHillRestorations |
Nov 30 2009, 12:00 PM
I. I. R. C. Group: Members Posts: 6,795 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
A couple things that have helped me with sheet metal screws.
When re-installing a sheet metal screw, put the tip in the hole and press down lightly, the turn counter clockwise until you feel it click, then turn clockwise. This lines up the threads so you don't cut new ones. I was working on a customer's car and showed him this tip. He sells medical hardware for bone implants and joint repair and said this is exactly the same thing they teach the Dr's to align the threads on the bone hardware. The other thing I've done is tap the sheet metal by drilling the hole 1/8" smaller than needed, and then bugle the hole with a tapered punch to the correct size needed for the tap, using the correct size drill bit (for the tap) as a guide. |
kenshapiro2002 |
Dec 4 2009, 09:42 AM
kenshapiro2002 |
Dec 11 2009, 12:12 PM
kenshapiro2002 |
Dec 11 2009, 12:13 PM
Lo-Fi Version | Time is now: 15th January 2025 - 06:04 AM |
