6 Pages V < 1 2 3 4 5 > »
> Porsche 914 Automatic, I just couldn't resist...Added a video
quadracerx
post Dec 9 2009, 09:16 PM
Post #41
That is soo cool....good luck with the speedo...hope its something simple..
computers4kids
post Dec 9 2009, 10:06 PM
Post #42
Love these little cars!
QUOTE(kg6dxn @ Dec 9 2009, 06:09 PM) *
That's awesome! Your liucy you bought it when you did... I was in contact with him also... You beat me to it. Keep us posted on the progress.
When his ad came out the first time, he did not post any pics but I had contacted him anyway. We talked about me coming that weekend, even got pics, then I got real sick, H1N1 and life literally stopped for me for two weeks. When I was feeling better, I just assumed the car was sold, but then I saw he re-posted....and the rest was history. I still can't believe this car sat there for two weeks while I was sick without someone sealing the deal.
oldschool
post Dec 9 2009, 10:19 PM
Post #43
QUOTE(computers4kids @ Dec 9 2009, 08:06 PM) *
I was thinking of getting it, but how do tell the wife about the 3 914 not running (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/chair.gif)
dw914er
post Dec 9 2009, 11:32 PM
Post #44
Planning Cities
dude... that's awesome!
charliew
post Dec 10 2009, 01:46 PM
Post #45
I guess it was just meant to be yours. I think it's really a special car. That looks like a speedo cable going up over the top of the tranny under the fill tube by the motor to tranny seam but I don't see it near the rear anywhere. See if it's under the dash or pop the speedo out a little. I find it hard to believe a older lady could get by with the tach for the speed.
charliew
post Dec 10 2009, 01:48 PM
Post #46
My friend says he knows of a flared 914 thats been in storage a long time at a old hot rodders place but I really don't have a place for another project and I might have to promise not to change it up.
iamchappy
post Dec 11 2009, 11:05 AM
Post #47
It all happens so fast!
It might even be possible to put the Audi 5000 manual transmission in a 914.
Sounds like the internals are 915
Interesting read, more uses for the Audi 5000 manuel transmission claims it can handle 450 + horsepower.
http://www.lambolounge.com/chassis/Transmi...n/5000/5000.asp
http://www.lambolounge.com/chassis/Transmi...i-915/index.asp
ClayPerrine
post Dec 11 2009, 11:57 AM
Post #48
QUOTE(iamchappy @ Dec 11 2009, 11:05 AM) *
Audi 5000 trans aka Porsche 944 Trans. They seem to get replaced alot......
quadracerx
post Dec 11 2009, 02:55 PM
Post #49
In the risk of sounding stupid....Which I tend to be....why cant we just use a 944 Trans....will it bolt in a 914 for the most part?
iamchappy
post Dec 11 2009, 03:00 PM
Post #50
They connect with a drive shaft........
dlo914
post Dec 11 2009, 03:11 PM
Post #51
Whatchu' lookin' at?!?!
QUOTE(quadracerx @ Dec 11 2009, 12:55 PM) *
I'm guessing it's similar to the use of 2WD to AWD subaru transmissions. The 2WD trans you don't have to worry about blocking/disabling the the other drive portion of the trans. While the AWD trans you have to purchase a kit to disable and block off the rear drive section of the trans.
What i meant was the 944 trans is located at the rear of the car w/ a driveshaft coming from the front of the car from the engine. While the Audi 5000 version is attached to the engine (like the 914) and there's no messing w/ blocking off the input hole for the driveshaft.
Porsche 928
(IMG:http://static.howstuffworks.com/gif/porsche-928-85-4-56.jpg)
Audi 5000 (ignore the V8)
(IMG:http://www.lambolounge.com/Chassis/Engine/BMW-V12/Ron/image001.jpg)
ClayPerrine
post Dec 11 2009, 03:58 PM
Post #52
The 944 trans doesn't have a throwout bearing or arm. It has a tube for the shift linkage to run through the bell housing. The rest of the trans is identical. The driveshaft is clamped to the input shaft on the trans, and a big plate is bolted to the bell housing, adapting it down to the torque tube.
For the most part, the audi and 944 transmissions are interchangeable.
Cupomeat
post Dec 11 2009, 04:44 PM
Post #53
missing my NY 914 in VA
QUOTE(dlo914 @ Dec 11 2009, 04:11 PM) *
Porsche 928
I think that is "Ignore the V12". Nice BMW V12... (IMG:style_emoticons/default/happy11.gif)
computers4kids
post Dec 12 2009, 04:12 PM
Post #54
I decided to go ahead and clean-up the look of the shifter inside the 914. I removed the the modified console and as you can see further down the end result is a much cleaner look...at least I like it. The gauges will end-up being intergrated into the 3 gauge dash cluster.
Before Picture
(IMG:http://computers4kidshome.com/Audi/before.jpg)
As you can see, the shifter is raised up about 1/2 inch, levers from the shifter actually protrude down into the tunnel.
(IMG:http://computers4kidshome.com/Audi/leftshifter.jpg)
If I wanted, I could cut the shifter mechanism tube that sticks upward and lower it about 4inches without too much problem. I would then either have to shorten the plastic shift mechanism cover or get a large boot. For now, I think I'm going to leave it be.
(IMG:http://computers4kidshome.com/Audi/rightshifter.jpg)
In this picture you see where normally a CA 75 has an EGR valve placed where the speedometer goes to and then leaves to be routed to the transmission. The cable coming from the Audi transmission is "Audi" and travels up the tunnel to this connector in the passenger foam cutout. The other side of the connector is a porsche speedo cable that travels up to the speedometer. I'm not to sure what this "connector" is but it makes the transfer from Audi part to Porsche part.
(IMG:http://computers4kidshome.com/Audi/audito914.jpg)
The new look... Eventually, I'll put a carpet kit in the car and it should look pretty good.
(IMG:http://computers4kidshome.com/Audi/after.jpg)
Joe Bob
post Dec 12 2009, 08:21 PM
Post #55
Why don't you have an uphostery shop make a leather boot and remove that big plastic uglee thingy.....not like you don't know what gear it's in.
computers4kids
post Dec 12 2009, 08:49 PM
Post #56
It was raining but wanted to go for a spin around the block. Not quite the "twisty" video that I hoped to first post, but at least it will give you a peak. Next time I'll have to figure out a better way of positioning a camera that will take some bumps...kept loosing the camera's focus from bumps.
https://www.youtube.com/watch?v=3UN2gZ-nYLA
oldschool
post Dec 12 2009, 09:48 PM
Post #57
Dude! that's so sweet I think I'm going to make a custom T-Shirt just for you, (IMG:style_emoticons/default/aktion035.gif) what app. is that,and I now I know were to put my iphone (IMG:style_emoticons/default/rolleyes.gif)
any rain inside the car after the drive?
computers4kids
post Dec 12 2009, 09:55 PM
Post #58
The iphone app is "speed-o-meter"...it's either free or $1, I can't remember. It's pretty darn accurate.
zx-niner
post Dec 12 2009, 10:08 PM
Post #59
This is so cool! Good for you.
rick 918-S
post Dec 12 2009, 10:53 PM
Post #60
Hey nice rack! -Celette
Porsche missed a market segment with that one! Very Cool!
- Lo-Fi Version Time is now: 26th December 2024 - 04:48 PM
