ss6 |
fun city... ![]() ![]() Group: Members Posts: 261 Joined: 2-February 03 From: Western Connecticut Member No.: 221 ![]() |
Got a set of Mueller's nifty suspension bearings, pressed the bearing tube into the trailing arm (BF threaded rod and a LOT of elbow grease), proceeded to test fit the bearings. Fits fine on the outboard end, but the inboard end won't accept the bearing.
Measured the tube ID, and found a slight oval, ie 1.318 - 1.338. The bearing OD that has to fit in there is 1.330. So will the bearing tolerate this or am I going to have to go find a machine shop??? |
Lo-Fi Version | Time is now: 29th April 2025 - 01:15 PM |
