> Why are my heat exchangers not meeting up to the hanger on transmissio
x98boardwell
post Jan 4 2010, 09:58 PM
I own a 75 2.0. I have converted all of the exhaust to the earlier 73-74 2.0 exhaust with all of the proper hangers, heat ducts, etc.
My problem is that when one of the exchangers meets up to the mount where it meets the muffler it is overlapped by the hanger by almost 2 inches. Then, on the other heat exchanger it is short from reaching the hanger by almost 2 inches. For some clarification when I am looking from the rear of the car, both exchangers are aimed more toward the passenger side (to the right) about 1 inch or so which is screwing things up. I was under the impression that the mount for the 2.0 is symetrical so there should be no issues whether or not I flip it around on the transmission correct?
Also, I know that I have all of the correct hangers, 2.0 exchangers, duct work, etc. but I cannot figure out why it would be sooo off. When I took the 75 exhaust off everything fit perfectly so I know everything is straight. The only thing I can think of is what if the exchangers that I purchased came from a car that had been in a wreck and were tweaked to one side??? not sure.
Can anyone offer some advice as to why this could be or how to fix?
Thanks in advance,
Bryan
Sleepin
post Jan 4 2010, 10:05 PM
Flip the mount. It looks symmetrical...but IIRC it is not, and one side of the mount goes in front of the muffler flange and one side goes behind.....but I have slept since then.
GeorgeRud
post Jan 5 2010, 12:11 AM
It does sound like you have the mount backwards. It also helps to have all the fasteners installed, but not totally tightened (at the heads as well!) as there sometimes is a bit of tweeking that is necessary to get everything to fit. Once all the fasteners are installed loosly, then tighten everything up.
BTW, on my cars (914-6s), the hanger does fit on the same side of the muffler flanges on both sides.
davep
post Jan 5 2010, 08:20 AM
914 Historian
When installing an exhaust system, all of the fasteners must be kept loose until all of the components are attached. Generally, the muffler can be tightened up first, and the heads last.
sixaddict
post Jan 5 2010, 09:11 AM
Help for those that hadn't even asked...Davep is right on....Was wondering what the heck happened to my six and loosened header nuts at heads and everything connected....It will probably go "BOING" When the muffler is removed but I got it on...Thanks from me !
Amazing how basic mechanical principles can be forgotten with age.....sucks actually !
x98boardwell
post Jan 5 2010, 01:35 PM
Guys,
Thanks for the help. The muffler bracket/hanger needed to be flipped. Everything is good. Man, I thought by looking at it that it must be even on both sides but guess not. Glad it wasn't something serious.
Thanks again,
Bryan
Sleepin
post Jan 5 2010, 01:39 PM
QUOTE(x98boardwell @ Jan 5 2010, 12:35 PM) *
Guys,
Thanks again,
Bryan
Bam! Nailed that one! (IMG:style_emoticons/default/aktion035.gif) ....I mean....I finally got one right! (IMG:style_emoticons/default/lol-2.gif)
6freak
post Jan 5 2010, 01:54 PM
MR.C
hay thats my line
- Lo-Fi Version Time is now: 2nd January 2025 - 03:30 PM
