Have you installed Trunk Pivot, JWest Engineering product |
etcmss |
Jan 9 2010, 10:07 AM
etcmss Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest |
some of us aren't good at welding and this product seems to be alternative to broken pivots. Anyone have experience with this?
http://www.jwesteng.com/porsche/914/pivot.htm |
ChrisFoley |
Jan 9 2010, 10:24 AM
I am Tangerine Racing Group: Members Posts: 7,968 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I like them.
One caveat - the left and right sides are mirror images and shouldn't be interchanged. Unfortunately, the way they have been packaged hides the identifying mark where you won't see it if you don't look for it. We serviced a car where someone else installed them backwards. (IMG:style_emoticons/default/screwy.gif) |
ahdoman |
Jan 9 2010, 10:26 AM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
I used them on my last car. They worked great! The adjustability is great for aligning the trunk. The only concern you need to have is if yours broke make sure they aren't rusted through the inner fender. If they are there won't be anything strong to attach them to.
Jerry75914 |
Jan 9 2010, 01:02 PM
Member Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California |
I've used them on mine and I'm really happy with them. Nice is, since they are bolted in with four bolts...super solid fix. Unless the car rusts around them, no way will the hinge be an issue ever again!
jgara962 |
Jan 9 2010, 01:57 PM
Yo, this is how I roll Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
I put them on my car a few months ago and it is a great product. Having someone to help makes a big difference, I couldn't imagine trying to do this project on my own. Even with two of us, it took a while to install. Most of the time was grinding off the old welds from the original trunk pivots.
etcmss |
Jan 9 2010, 05:04 PM
Thanks to all---I will probably pursue.
JWest |
Jan 9 2010, 05:14 PM
I like them. One caveat - the left and right sides are mirror images and shouldn't be interchanged. Unfortunately, the way they have been packaged hides the identifying mark where you won't see it if you don't look for it. We serviced a car where someone else installed them backwards. (IMG:style_emoticons/default/screwy.gif) There is a picture in the instructions that should keep from installing on the wrong side - the only reason they are different is to facilitate drilling access, so it is not really a big deal if they are wrong. I could just add a left/right sticker on the outside would solve that problem. |
PanelBilly |
Jan 9 2010, 06:03 PM
914 Guru Group: Members Posts: 5,864 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I'd tag them Driver and wishing I was the driver. Left and right can be confusing to some.
ChrisFoley |
Jan 9 2010, 07:44 PM
There is a picture in the instructions that should keep from installing on the wrong side - the only reason they are different is to facilitate drilling access, so it is not really a big deal if they are wrong. I could just add a left/right sticker on the outside would solve that problem. Its almost impossible to install all 4 bolts if mounted on the wrong side of the car. Nothing wrong with the product at all, but stamping them L and R on a surface that becomes hidden once you package them is enough to screw up some people - the same people who are too smart to read the instructions, lol. The car we found them installed incorrectly on had the backing plates still stuck to the mounting plates. |
jsayre914 |
Jan 9 2010, 10:11 PM
Speed Up !!! Group: Members Posts: 3,206 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I put one on my car because i brove one pivot off, then 1 year later gigured i would finish the job, and installed the other. I love them, great product.
(IMG:style_emoticons/default/beerchug.gif) |
Slider |
Jan 9 2010, 10:38 PM
Problems are like cockroaches you find 1 and theres a 100 more Group: Members Posts: 223 Joined: 11-March 07 From: Fort Collins Colorado Member No.: 7,591 Region Association: Rocky Mountains |
i installed these last spring since i had one side broken since i got the car. it was pretty easy to get on and like others have said its real easy to get the sides mixed up so be careful
tat2dphreak |
Jan 15 2010, 02:03 PM
I used them, and love them on my car I didn't get one side drilled perfectly, but was able to adjust it... make the same mistake with weld in and you are screwed... you'd have to start over, meaning new hinges again... I DID have to pay attention to the sides, but they ARE labeled
maybe the label needs to be D and P instead of L and R for some of us (IMG:style_emoticons/default/wink.gif) |
JWest |
Jan 15 2010, 02:32 PM
Thanks for the feedback - I have a new sticker to use to help identify which side is which - let me know what you think.
jmill |
Jan 15 2010, 02:45 PM
Thanks for the feedback - I have a new sticker to use to help identify which side is which - let me know what you think. (IMG:style_emoticons/default/av-943.gif) Your alright. |
tat2dphreak |
Jan 15 2010, 02:51 PM
Chris Pincetich |
Jan 15 2010, 02:55 PM
Well, that sticker sure clears things up
(IMG:style_emoticons/default/av-943.gif) The hinge fix was one of my very first DIY 914 projects. I got a box full of JWest upgrades, and they have all been easy installs followed by trouble-free performance. Thanks James (IMG:style_emoticons/default/beerchug.gif) |
Jan 15 2010, 03:08 PM
Resident German Group: Admin Posts: 41,944 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
etcmss |
Jan 15 2010, 03:26 PM
so how long did the technical writer take to create it? it is worth the laugh. if you had to read it all you really need some help to get these installed
bandjoey |
Jan 15 2010, 05:14 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Don't forget to add the disclaimer:
"This only applies to 914 owners. All others...it's Left." (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) |
Lou W |
Jan 15 2010, 07:14 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
Here's my installation, it went in great:
Lo-Fi Version | Time is now: 26th December 2024 - 05:52 PM |
