rs182 |
Newbie ![]() Group: Members Posts: 11 Joined: 18-September 11 From: Las Cruces nm Member No.: 13,569 Region Association: Southwest Region ![]() |
Anyway, Originally, I was sourcing a JDM WRX EJ20 motor/gearbox combo; hoping to get 200+ish Hp to the rear wheels, but ended up the motor to be the 98' JDM WRX STi RA V4 motor with vf22 turbo (rated 280ps, and possibly up to 300chp stock? (IMG:style_emoticons/default/smilie_pokal.gif) ) with the Sti gear box TY752vbcaa (4.44 FD) A little more than what I intended to do, but extra hp is nice? (IMG:style_emoticons/default/rolleyes.gif) The only thing I'm really worried about is the old Subaru Gear box, can it handle the amount of torque was originally set for awd, now to a 2wd? (IMG:style_emoticons/default/confused24.gif) And question on the origianl Air to Air IC you had, did you have major issue of not cooling the air sufficient enough? Will it hurt the turbo or over heating it? I was thinking to do just the air to air right now (rather than the water to air) to save some more plumbing (fabrication) and weight. The motor you have is the well known ej20k. (I had one swapped in my 99 2.5rs) These motors are very highly tuned and MUST have at least 93 octane if you want it to live at all. They are known for losing rod bearings because people run them on 91 octane and bounce off the 8200 redline. I would highly recommend going through the motor before you install it (they have a fairly high failure rate compared to other jdm motors such as the ej20g, h,r, 205 and 207.) They are amazing little motors as long as you get a good tune on it using a standalone such as apexi power fc, or vipetec. As far as the transmission you will be fine using it in a FWD configuration. They are very stout little transmissions. Being a STi RA theres a good chance it will have DCCD as well. You obviously dont need it since you are not going awd but it is worth good money to someone else. I would recommend a front mount intercooler if possible. The biggest problem with no having a efficient IC is that your knock count will go through the roof and kill your motor pumping that hot air in there. Feel free to PM me if you need wiring diagrams, Places to get parts, or what ever. I am new to 924's but have ALOT of Subaru experience OP Very nice build I just picked up a 72 and have a ej20r twin turbo sitting in the corner of the shop waiting to go in (IMG:style_emoticons/default/biggrin.gif) |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
You're in Las Cruces? These days I'm spending most of my life in El Paso hotels.
Hey Jeff, I see you're reading this topic too. How's things? |
rs182 |
You're in Las Cruces? These days I'm spending most of my life in El Paso hotels. Hey Jeff, I see you're reading this topic too. How's things? Yep Las Cruces (IMG:style_emoticons/default/biggrin.gif) El Paso Hotels sounds like a horrible way to spend any of your life haha If you ever in Las Cruces we should get a beer ! I am picking up my first 914 in Albq. NM tomorrow (IMG:style_emoticons/default/driving.gif) |
csdilligaf |
Member ![]() ![]() Group: Members Posts: 106 Joined: 18-April 12 From: San Diego CA Member No.: 14,397 Region Association: None ![]() |
the shop that did the work on this project is thirteen 40 or 40 thirteen in Modesto? I tried to google something and came up empty. Since they did such a nice job on this one is it something they do now?
DBCooper |
You didn't get my PM? It's 40-Thirteen in Modesto, but it's really one guy who works in the Bay Area and evenings and weekends does projects he thinks would be cool. The 914 was a one-off, just to do it. Right now he's finishing an LS1 Volvo 244 (http://forums.turbobricks.com/showthread.php?t=222596).
(IMG:http://www.914world.com/bbs2/uploads_offsite/i53.photobucket.com-2618-1334947936.1.jpg) Google 55superbeetle to see some of his other projects. His name's Jeff and you can probably contact him that way, or PM your e-mail and I'll give it to him. . . |
CptTripps |
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,585 Joined: 26-December 04 From: Tuscaloosa, AL and Akron, OH Member No.: 3,342 Region Association: Upper MidWest ![]() |
Quick question: Ever think of using a Boxster shifter/cables?
http://bit.ly/1gWnZIK If those cable lengths are close, that may be a real easy setup. |
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
I understand you have some control with the DCCD but I've no experience with them.
If it's really a pure clutch type LSD rather than a TBD then it's gonna suck at AX unless the breakaway torque is pretty darned low. How low it should be depends on the rest of the suspension and driving style. The clutches make it want to go straight on both accel AND decel. The TBD goes open on decel. Who knows the DCCD settings well enough to report on 'em, and will it work with a 2WD? |
DBCooper |
We tuned it a tad fat with max 10 pounds boost so I only have 205 tq/hp at the wheels, half a V8. We ran a 13.7 at 106 with the 901, babying the car off the line trying to keep it in boost and then shifting like old ladies. I'm guessing we'll be in the high 12's with this stronger transmission. Looked at this thread again after a llong time and see I can update this part. My son did run the car again at an official event, did a best of 13.006 at 109 mph. That run was mid-afternoon on a 100 degree day so they expected an easy 12 in the evening with cooler temperatures Unfortunately for that evening run they put on a borrowed pair of slicks and immediately broke an axle. Since I don't drag race that means that 13.006 is the fastest this car will ever go, but it's tantalizingly close to being a 12 second car. Not bad for a car that wasn't even built to drag race. Acceleration is the purest measure of horsepower short of a dyno. That ET is seven tenths of a second faster than the previous fastest 13.7, but we know there was no more horsepower. In fact the engine, tires, exhaust and every other part of the car were exactly the same, the only change was to switch out the 901 for the Subaru transmission. For a lot of reasons for sure, but that transmission change, in itself, made the car significant faster. Food for thought. |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
do you have pictures of what the kit for the transmission contains to block off the rear output shaft?
Also, is there a cradle diagram out there on the internet somewhere? Just starting to talk with my son about this...... Rich |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,698 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Rich, the "kit" is just a small sleeve. That and you remove a few parts. One you can resale for $250.00+. You will need a piece of 1/8 aluminum to make a block off plate for the rear of the transmission. This piece's dimensions are transferred (scribed) off the old rear plate. That is a 20 min job. The cradle is about $150 in materials + a $99 tube bender @ HF. It's a Hell of a lot harder than buying one of Ian's cradles but I enjoy building and I have a tube bender left over. The shifter will run about $200 if you make your own with an MR2 used shifter and a set of cables and ends. It's pretty well documented in some of the recent Suby threads. (IMG:style_emoticons/default/beerchug.gif)
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
We tuned it a tad fat with max 10 pounds boost so I only have 205 tq/hp at the wheels, half a V8. We ran a 13.7 at 106 with the 901, babying the car off the line trying to keep it in boost and then shifting like old ladies. I'm guessing we'll be in the high 12's with this stronger transmission. Looked at this thread again after a llong time and see I can update this part. My son did run the car again at an official event, did a best of 13.006 at 109 mph. That run was mid-afternoon on a 100 degree day so they expected an easy 12 in the evening with cooler temperatures Unfortunately for that evening run they put on a borrowed pair of slicks and immediately broke an axle. Since I don't drag race that means that 13.006 is the fastest this car will ever go, but it's tantalizingly close to being a 12 second car. Not bad for a car that wasn't even built to drag race. Acceleration is the purest measure of horsepower short of a dyno. That ET is seven tenths of a second faster than the previous fastest 13.7, but we know there was no more horsepower. In fact the engine, tires, exhaust and every other part of the car were exactly the same, the only change was the Subaru transmission. For a lot of reasons for sure, but that transmission change, in itself, made the car significant faster. Food for thought. The 109 trap is the real number there. Thats quite a good number! |
hbgsteve |
Newbie ![]() Group: Members Posts: 12 Joined: 12-October 11 From: Healdsburg Ca. Member No.: 13,666 Region Association: None ![]() |
Absolutely knock my socks off gorgeous. beyond words beautiful
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Some delay because the Tilton pedals were backordered. They're now in, though not yet plumbed. At the end of the day this is easier than modifying the 914 cluster to add a clutch master. Not only that I just plain like Tilton pedals. (IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268141909.1.jpg) Not too far from driving it now. Only bummer is in the background of every one of these photos I see clean-up and finish work that still has to be done. That's cool, get it running the way I want first and then go back through everything to make it all pretty. Are you using Howe Racing G3 Masters, and what sizes did you use? If you used the 3/4" how does the clutch pedal feel since your using the stock Subaru slave? Needed to re-read the thread, found it in an earlier post "I used Tilton pedals to get a hydraulic M/C (read the whole thread, it's described with photos). Only down side is that using the smallest available Howe M/C's I still have too much pedal pressure (Carrera front calipers, 914 front on the rear), so I'm looking to convert to calipers with bigger pistons." |
DBCooper |
Yes, I'm tall and the Howe were the shortest m/c's, getting cluster the furthest forward. Both are 3/4". The clutch is fine, perfect even, but the brake gives way too much pedal pressure. It's driveable, and I guess some people like a harder pedal, but I come from sportbikes and prefer more feel. I've thought about sleeving the brake master, but have a full set of 951 calipers that I can use that would probably both upgrade the brakes (Carrera vented discs) and give a better pedal. It's on the to-do list. Not high on the list, but on it.
As a heads-up though, we converted my son's car last year and instead of a new cluster we used a bracket made by 76-914 that let us keep the stock pedal cluster. It's a simple and very elegant solution that uses a stock (and cheap!) Civic clutch master alongside the stock brake master. The stock clutch cable hook was converted from a cable puller into a clevis and pusher. Look that up, I think he posted a drawing with dimensions, just flat stock. Works great and highly recommended. |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,842 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
As a heads-up though, we converted my son's car last year and instead of a new cluster we used a bracket made by 76-914 that let us keep the stock pedal cluster. It's a simple and very elegant solution that uses a stock (and cheap!) Civic clutch master alongside the stock brake master. The stock clutch cable hook was converted from a cable puller into a clevis and pusher. Look that up, I think he posted a drawing with dimensions, just flat stock. Works great and highly recommended. Sounds like something I could use. |
914forme |
Yes, I'm tall and the Howe were the shortest m/c's, getting cluster the furthest forward. Both are 3/4". The clutch is fine, perfect even, but the brake gives way too much pedal pressure. It's driveable, and I guess some people like a harder pedal, but I come from sportbikes and prefer more feel. I've thought about sleeving the brake master, but have a full set of 951 calipers that I can use that would probably both upgrade the brakes (Carrera vented discs) and give a better pedal. It's on the to-do list. Not high on the list, but on it. As a heads-up though, we converted my son's car last year and instead of a new cluster we used a bracket made by 76-914 that let us keep the stock pedal cluster. It's a simple and very elegant solution that uses a stock (and cheap!) Civic clutch master alongside the stock brake master. The stock clutch cable hook was converted from a cable puller into a clevis and pusher. Look that up, I think he posted a drawing with dimensions, just flat stock. Works great and highly recommended. I'm 6'2" so I am a little large in the 914, my biggest issue is with the pedals, as I hope my 12 Double wides fit. And don't get hung up on the pedals. And yes 76-914s pedal system is great. I guess I could go that route, again (IMG:style_emoticons/default/headbang.gif) I sold mine, it used a Willwood M/C. I was looking for a better pedal, and not having to build MC stiffening plate for the car. I also really hate the 914/911 MC, the fluid input leaves and the plastic lines drive me nuts. Once its in it is great, getting it in and sealed while in the car, pain in the (IMG:style_emoticons/default/bootyshake.gif) DB thank you for your input, greatly appreciated. Have you tried changing the pedal ratio on the Tilton's ? 3/4 inch = 19.050mm so I can't see that making the pedal overall stiff, I have run a 19mm with Carrera Calipers front and rear, and never had a pedal modulation issue your describing. |
DBCooper |
You'll fit. I'm a bit taller and am totally comfortable in the car. Also 12's but only single wide, and the Tilton's fit me great. About pedal pressure don't forget the Tilton brake pedal is trying to compress two m/c's, not just one. I've looked at changing the pivot point, but the Tilton plungers run in cast bosses, so not easy to move. Doing that would also change the stroke, which is close to perfect right now, so the only logical thing is to change the m/c bore. Unfortunately Howe doesn't make a smaller one so I'm stuck. Interesting thing is that I have my son's car here, also a 914/WRX but with the adapted 914 cluster, so I can do a direct comparison between the two. I'm thinking about removing the Tilton's from my car and converting the stock like his. It really is better.
Same thing on the shifter. My son has the same MR2 shifter and cables, but his uses the linkage with the bell crank. My cable that rotates the shaft is longer and curves around for a direct shot at that bracket, so there's no bell crank, nothing mechanical in the linkage. In a direct comparison between the two, mine shifts lots nicer than his, both light years better than stock. In fairness we chose all all off-the-shelf components so we could convert his 901 to the Subaru transmission in one weekend, to get it done before his HOA even noticed. I say we, but he actually did all the work. I'm old so I supervise. I don't know anyone else who has two almost identical cars to compare side-by-side like that, but it's enlightening. It's not just in-theory but theory compared with practice. As more and more of these cars get converted I think we're all looking over each other's shoulders and evolving things to be simpler and better. And that's good for all of us. |
914forme |
Okay well thank you again, made for an interesting discussion.
76-914 |
Same thing on the shifter. My son has the same MR2 shifter and cables, but his uses the linkage with the bell crank. My cable that rotates the shaft is longer and curves around for a direct shot at that bracket, so there's no bell crank, nothing mechanical in the linkage. In a direct comparison between the two, mine shifts lots nicer than his, both light years better than stock. In fairness we chose all all off-the-shelf components so we could convert his 901 to the Subaru transmission in one weekend, to get it done before his HOA even noticed. I say we, but he actually did all the work. I'm old so I supervise. IIRC, I somewhat copied your holder because of 1 reason Paul. No moving parts. KISS. It is still as smooth as day 1. (IMG:style_emoticons/default/beerchug.gif) |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
Gotta bump this thread DB kept up the updates and saved a lot of time for new attempts at this. There are so many good ideas here and on brittons thread and most all of the ideas are in one place. I realized reviewing this stuff how much has slipped away from me, especially the suby tranny differences on britton't thread. I hope it all gets done or I will have a lot of parts that only I know where to put them or how they go. I gotta find a air to water cooler yet. the one thing I missed was the length of db's long rotating cable. maybe nine or eleven feet but boy eleven seems awful long. might just have to wait on that till I mount the shifter his tranny might not be exactly where Ian's cradle puts the tranny. I like DB's cradle as it mounts solid to the body and gives more strength to the body and then mounts the motor and tranny in rubber and urethane, gotta work on Ian's mount some, I do like the idea of getting the tranny out by itself though. I'm doing cardio therapy but after 6 weeks I'm not sure it is worth it, I get winded at the weirdest times. Guns under the ac are easier projects when it is 101 outside. I bet I hold the record time for the longest parts collector on the 914/suby/911suspension here.
Lo-Fi Version | Time is now: 19th April 2025 - 07:47 AM |
