Welding Saftey around Gasoline? |
detoxcowboy |
Jan 12 2010, 11:06 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Ignornat questions but..
When welding in the front trunk A.C. hole is it safe not to pull the gas tank? Full tank gas better? When welding in the engine compartment (shelf below battery where fuel lines have to be disconnected as they pass through that shelf) what do you do with open fuel lines, cap them? wet towel? Engine will be pulled so I could not just leave them connected unitl I finished?? I have no problem smoking around gas just welding is a little hot spark?? |
messix |
Jan 12 2010, 11:12 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
BOOM! (IMG:style_emoticons/default/welder.gif)
rick 918-S |
Jan 12 2010, 11:20 PM
Hey nice rack! -Celette Group: Members Posts: 20,825 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Pull the tank. It's not that hard. It only takes one mouse nest under the tank to open a can of whoopass you will regret. Move the rear lines over and you should be fine.
detoxcowboy |
Jan 12 2010, 11:50 PM
(IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/welder.gif) Ba boooom!! Thanks Rick!! Just move the lines over but plug them correct? the engine is going to be out so there will be nothting just move them over connected.. Mouse Nest?? Do you mean seapage? There ain't no mice up front they all working the flywheel.. Seriously though under my tank is clean clean.. been in under there a few times this year, nothing but what the p.o. dropped golf tees and washers//. |
messix |
Jan 12 2010, 11:53 PM
throw a big wet towel over the lines and keep them away from where your gonna weld and you'll be fine.
Rand |
Jan 13 2010, 12:12 AM
Echo Troy. Simple, no worries. Throw some wet towels over what scares you.
Keep ventilation open! You wanna talk about real freaking out, my dad used to weld on gas tanks. He would hook a tube from the exhaust of a running car into the intake of a tank, let that flow a bit, and weld away. |
aircooledtechguy |
Jan 13 2010, 10:18 AM
You wanna talk about real freaking out, my dad used to weld on gas tanks. He would hook a tube from the exhaust of a running car into the intake of a tank, let that flow a bit, and weld away. You do the same thing with aircraft. They call it gas-freeing the tanks. Blow enough air through a tank for a given period of time (depending on tank size) and fuel used. Viola! It's safe to weld on. I knew a guy who would let a tank basically dry out for a 1/2 day, then, with a lit torch at arms length, go to the filler neck. A flame would shoot out for a second (read that: explode out). No more vapors. Safe for welding. THAT was a little foolish for my taste. |
Scott S |
Jan 13 2010, 10:30 AM
Small Member Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
throw a big wet towel over the lines and keep them away from where your gonna weld and you'll be fine. I will be installing the Rick Johnson mount for my -6 conversion - is ot ok to go this route when dealing with the exposed ends of the center tunnel fuel lines? Thanks! |
sww914 |
Jan 13 2010, 10:36 AM
I've done all the stuff they say to not do and I'm still equipped with enough fingers to type. Gas doesn't really light all that easily, IMO. But if it does light and there's a lot of it it gets loud.
ericread |
Jan 13 2010, 10:42 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
There's always the idea of submerging the entire car in water, and welding under water. Much safer... (IMG:style_emoticons/default/rolleyes.gif)
Dr Evil |
Jan 13 2010, 02:26 PM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I have heard of dry ice being used. Just drop a few chunks in the empty tank and it cools the tank as well as filling it with fire retardant CO2.
messix |
Jan 13 2010, 07:03 PM
throw a big wet towel over the lines and keep them away from where your gonna weld and you'll be fine. I will be installing the Rick Johnson mount for my -6 conversion - is ot ok to go this route when dealing with the exposed ends of the center tunnel fuel lines? Thanks! liquid gasoline is not all that dangerous.... but the vapor is! just protect anything that you don't want splattered with welding sparks and that should have some flammable vapor, liquid or material. if yer gonna weld on the fire wall ya might wanna take the back pad out of the passeger compartment. (IMG:style_emoticons/default/slap.gif) |
detoxcowboy |
Jan 13 2010, 07:05 PM
throw a big wet towel over the lines and keep them away from where your gonna weld and you'll be fine. I will be installing the Rick Johnson mount for my -6 conversion - is ot ok to go this route when dealing with the exposed ends of the center tunnel fuel lines? Thanks! liquid gasoline is not all that dangerous.... but the vapor is! just protect anything that you don't want splattered with welding sparks and that should have some flammable vapor, liquid or material. if yer gonna weld on the fire wall ya might wanna take the back pad out of the passeger compartment. (IMG:style_emoticons/default/slap.gif) Thanks Meesix for the tip, .. |
ME733 |
Jan 14 2010, 08:31 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) ...Lots of mostly good Ideas , have been submitted. Consider this approach...!. REMOVE GAS TANK...blow out the disconnected fuel lines, shop air.....allow to air dry a day or two....2. move front and rear fuel lines , out of the way as far as possable. cover and wrap them with large soaking wet towels....3. have a FIRE EXTINGUISHER close by, and a hose with nozzle preadjusted for a spray pattern.(to cool , burning materials,and smother flames). (IMG:style_emoticons/default/popcorn[1].gif)
Geezer914 |
Jan 14 2010, 05:39 PM
Geezer914 Group: Members Posts: 1,797 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Pull the tank and plug the lines, why take a chance of ending up in a burn unit. Gas and sparks don't mix. Just ask the guy who tried to look in his gas tank to see how much gas was left and used a match.
Rand |
Jan 14 2010, 08:50 PM
It's not necessary to pull the tank and plug/flush the lines. Leave it connected and it's plugged/sealed by default. How is a welding spark going to get to the gas? If you have a leak? You could bounce sparks off your gas tank all day.
If you have wet gas puddling around, it will burn. If you have contained fumes it will explode!! Obviously make sure you don't have either. If you make sure you don't have leaks, you do have good ventilation, and throw a wet towel over anything that could leak fumes or be vulnerable to melting under a spark, it's just not a big deal! The original question was about welding a front trunk AC hole. It's not like he's using a cutting torch to cut 1/2" plate right above the gas tank spout. But whatever. Do what makes you feel safe. I just don't like doing a bunch of unnecessary work for no valid reason. |
detoxcowboy |
Jan 14 2010, 11:16 PM
It's not necessary to pull the tank and plug/flush the lines. Leave it connected and it's plugged/sealed by default. How is a welding spark going to get to the gas? If you have a leak? You could bounce sparks off your gas tank all day. If you have wet gas puddling around, it will burn. If you have contained fumes it will explode!! Obviously make sure you don't have either. If you make sure you don't have leaks, you do have good ventilation, and throw a wet towel over anything that could leak fumes or be vulnerable to melting under a spark, it's just not a big deal! The original question was about welding a front trunk AC hole. It's not like he's using a cutting torch to cut 1/2" plate right above the gas tank spout. But whatever. Do what makes you feel safe. I just don't like doing a bunch of unnecessary work for no valid reason. Rand, I could not agree with you more; The input was varied quit a bit. I can see that I would not be in danger on the front or even engine comp, fumes or something extra I coud not see/understand which is one reason I asked to fill the tank first. If I created enough heat to penetrate that far I would not have a front trunk at all. The chance that I have a leak or even a small pool of gas under the tank is minimal as I have changed everything down there and have been under there a couple times this year. and the spark going the one in a million jump to down the opening around the tank to underneath and staying hot enough long enough to spark, it is crazy odds. I just asked in the begining to check prior as I do not think I know everyting. Wet towel ect. to be certain is good enough. I have spilled gas all over me and on the driveway before and I lighted cigs all through the ordeal.. Fumes have to be concentrated and i am bascially outside no garage. All the input confirmed my original thoughts, thank you everyone. There is another reason I ask about around gas safety. I loss 90% of my smell sometimes it is better than others but it can be dangerous, I have accidently inhlaed flooring stripper all day and did not realize how much unitl I got sick headache./. |
Joe Bob |
Jan 14 2010, 11:50 PM
JB weld or pull the tank, fill with water...or have a pro do it. Unless you LIKE having no eyebrows and a dent in yer forehead.....
ChrisFoley |
Jan 15 2010, 04:39 AM
I am Tangerine Racing Group: Members Posts: 7,968 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
JB weld or pull the tank, fill with water...or have a pro do it. Unless you LIKE having no eyebrows and a dent in yer forehead..... The OP isn't asking about welding a leak in the tank. (IMG:style_emoticons/default/rolleyes.gif) Rand's advice is best. The chance of explosion is minimal working near the tank or lines unless confined vapors are sparked. At this time of year the only place where significant vapor concentration might exist is inside the tank itself. |
detoxcowboy |
Jan 15 2010, 09:29 AM
Lo-Fi Version | Time is now: 26th December 2024 - 08:53 PM |
