I officially finished putting my engine back in!, and it won't start =\ |
buhs914 |
Jan 13 2010, 01:34 AM
Not So Newbie Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region |
Well i took the engine out around 4-5 months ago to clean it up and fix a couple oil leaks. A couple weeks later i ran out of work and money and had been searching for a job since. I recieved a decent amount of money during Christmas and New Years and used most of it to finish my car. I get it all hooked up and about 95% road worthy and it doesn't start. (IMG:style_emoticons/default/headbang.gif) The starter spins and the engine gets gas but it doesn't even seem to try to start. I redid almost 100% of the ignition system about a year ago so most of the parts are newish. I checked the coil for a spark and it has one, but when i get to the cap I only get a spark on 1 out of 4 or sometimes no spark at all. So i checked to see if the points were working properly and noticed that the wire that goes from the points to the condenser was fried. I don't know how that happened because i'm 100% sure everything is hooked up right. I quadruple checked to make sure. Any ideas guys?
P.S. I need this car going before Friday so quick help would me much appreciated. Thanks! |
rick 918-S |
Jan 13 2010, 08:13 AM
Hey nice rack! -Celette Group: Members Posts: 20,825 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:style_emoticons/default/icon_bump.gif) Do you have the original coil? before installing the new points check the dizzy lead with a volt meter. (IMG:style_emoticons/default/confused24.gif)
rnellums |
Jan 13 2010, 09:49 AM
Professional Enthusiast Group: Members Posts: 1,667 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I'd say it looks like a problem in your dist. maybe the rotor isn't in the correct position when the points open? so it doesn't actually contact the cables. have you tried rotating the distributor around as you turn over the engine?
Cap'n Krusty |
Jan 13 2010, 09:51 AM
That wire fried because you had the wires at the coil mixed up. The point wire and the tach wire go to (-), the thick black wire goes to (+). The Cap'n
underthetire |
Jan 13 2010, 09:55 AM
ClayPerrine |
Jan 13 2010, 01:08 PM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
That wire fried because you had the wires at the coil mixed up. The point wire and the tach wire go to (-), the thick black wire goes to (+). The Cap'n (IMG:style_emoticons/default/agree.gif) And make sure that you didn't break the center contact off the cap when installing it. |
buhs914 |
Jan 13 2010, 01:43 PM
Yeah i noticed that i had mixed up the connections for the point wire but everything else was right. I'll install some new points today and go from there.
buhs914 |
Jan 13 2010, 06:32 PM
Ok so i put new points in and i moved the weber progressive choke wire to the correct side and now i get a good all around spark.. BUT the battery is too low to spin the starter anymore hahaha
buhs914 |
Jan 14 2010, 11:11 PM
Ok so i jumped the car and it started and took A LOT to get it to run. When it did run it ran for a short amount of time and stalled. It does this continually. It runs very sluggishly at first and then once it starts idling it dies.. almost like it's not getting gas but i'm almost positive it is. I also noticed that the carb was spitting quite a bit.. Help please!!
p.s. I've checked the ignition system and it's fine |
rnellums |
Jan 14 2010, 11:47 PM
It sounds to me like maybe the timing is off or a vaccum leak, I had the manifold gaskets on my single carb setup blow out when I ran that, made it really hard to get the right amount of fuel to the cylinders. Also my single carb tended to only give gas to two cylinders. Of course Dual carbs tend to be $$ but it made a huge difference for me. No chance of excess fuel pressure I suppose?
buhs914 |
Jan 15 2010, 12:02 AM
It sounds to me like maybe the timing is off or a vaccum leak, I had the manifold gaskets on my single carb setup blow out when I ran that, made it really hard to get the right amount of fuel to the cylinders. Also my single carb tended to only give gas to two cylinders. Of course Dual carbs tend to be $$ but it made a huge difference for me. No chance of excess fuel pressure I suppose? my manifold gaskets are fairly new. I think it might be the timing as well. I'll adjust it tomorrow and go from there! thanks. |
silver74insocal |
Jan 15 2010, 12:32 AM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
any chance your gas turned into caca while the car sat? does it run different with starter fluid?
buhs914 |
Jan 15 2010, 12:47 AM
Lo-Fi Version | Time is now: 26th December 2024 - 05:07 AM |
