> 94mm cylinder base gaskets? Where?
detoxcowboy
post Jan 14 2010, 05:02 PM
Region Association: Africa
1974 2.0 mahle euro spec pistons.. DOes anybody know where to get base gaskets for these? Recomendations ect??
McMark
post Jan 14 2010, 05:49 PM
914 Freak!
Every gasket set. If you can't find any let me know. I'll put some in the mail for you. But you only need them for adjusting deck height. For sealing, just use some Permatex or Curil T.
detoxcowboy
post Jan 14 2010, 05:56 PM
QUOTE(McMark @ Jan 14 2010, 03:49 PM) *
Thanks Mc Mark, I will do when I get there. I was trying to avoid buying the entire engine gasket set as I already have did that been there recently..
kconway
post Jan 14 2010, 06:16 PM
Looks like McMark has you taken care of. Here is a supplier for others who might be looking: http://www.cevw.com/index.php?products.html
Kev
Mark Henry
post Jan 14 2010, 09:12 PM
that's what I do!
If your doing a stroker no more than 3 shims in the stack.
I get my custom shims from RIMCO.
BTW you did do the CR math right? or are you guessing at the deck height? aircooled.net has a good CR calculator.
detoxcowboy
post Jan 14 2010, 10:26 PM
QUOTE(Mark Henry @ Jan 14 2010, 07:12 PM) *
Not guessing, just preparing for what and where I can get what I need. I am just a little wiser now after taking the car apart for a project only to find out I need somehting and do not know where to look or even worse end up waiting 2 weeks for something or getting the wrong part slow. I am doing a quadruple trifecta all projects at once and just need to be ready. I like aircooled.net di not know they had a calculator.. mayuer has a good one too.
- Lo-Fi Version Time is now: 26th December 2024 - 02:03 PM
