> Jack points?, best places
buhs914
post Jan 16 2010, 09:21 PM
Not So Newbie
So i know that the lift points are good for jacking but where else is good? I was just wondering because i've heard some debate on a few spots and i need to jack up one wheel for valve adjustment and timing..
P.S. (IMG:style_emoticons/default/ohmy.gif)h and i don't want to put too much pressure on my longs.
Kirmizi
post Jan 16 2010, 09:50 PM
I'd say get yourself some ramps.
At least to be safer.
Mike
McMark
post Jan 17 2010, 12:23 AM
914 Freak!
The rear 'donuts' are good places. The front 'donuts' are not. Since you have a late model engine mount, you can use that.
buhs914
post Jan 17 2010, 01:11 AM
Not So Newbie
yeah i have ramps and they worked great for my engine drop! so it is ok to use the engine mounting bar then?
Kirmizi
post Jan 17 2010, 02:33 AM
I back mine up on the ramps, then raise one side enough to get a tire free and support the raised side (on the engine bar) with a jack stand. It gives me enough room to slide around beneath the car without worrying about it falling.
Just do a search for "Evil Jackstands" about Gints' close call.
Mike
buhs914
post Jan 17 2010, 10:31 AM
Not So Newbie
QUOTE(Kirmizi @ Jan 17 2010, 01:33 AM) *
Mike
Actually i remember reading about that! My jack stands should be fine.. And i actually did the same thing with the ramps. it was already on them from the engine drop so i just jacked up the one wheel and used a jack stand on the engine bar. Thanks for the help though!
- Lo-Fi Version Time is now: 26th December 2024 - 09:29 AM
