2.7 Weber manifolds |
Scott S |
Jan 18 2010, 12:11 PM
Small Member Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All
I am plugging away on the conversion - at least as time permits.... sigh. I have the carbs (40 IDTP 13C), but have not picked up the manifolds. For the 2.7 do I run the normal 911 manifolds (part number 911101321R) with the 40 top bore and the 32 bottom bore? I need to know what to look for. If anyone has a set, I would love to chat. The 2.7 is stock and I plan on using the PMO spacers. As always, thanks a million... -Scott S |
carr914 |
Jan 18 2010, 02:50 PM
Racer from Birth Group: Members Posts: 122,545 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
I just sold a set a month ago, I don't have any more. You can also get the tall ones from PMO - They look better
vs |
J P Stein |
Jan 18 2010, 02:54 PM
Most 2.7Ls have 35mm intake ports. IIRC, the 74 only 'Normal" 2.7L had 32mm intakes.
Whatcha' got? |
Scott S |
Jan 18 2010, 03:03 PM
Hi JP -
It is a 77 911S. I was just told that it needs 40 over 36. Is it 35 or 36? I just want to make sure I am looking/searching on line using the right terminology. Thanks Again! (IMG:style_emoticons/default/beerchug.gif) Scott S |
J P Stein |
Jan 18 2010, 03:51 PM
Hi JP - It is a 77 911S. I was just told that it needs 40 over 36. Is it 35 or 36? I just want to make sure I am looking/searching on line using the right terminology. Thanks Again! (IMG:style_emoticons/default/beerchug.gif) Scott S My 76 was 35mm which I opened to 36. According to the book, all the USA 2.7Ls were 35 mm intake ports. The exceptions were the "normals"(150 hp) and the RS (NA in the USA) at 36mm. The "short" manifolds (the black ones in TCs pic) can be opened to 35-36. The "tall" (PMO) are 36mm from the get go, IIRC. The PMO insulators are 36 and (IMO)you want these and the manifolds as they block off the notch in the head as cast for the injector. There are also plugs for the air injectors next to the exh port. Pelican & EBS carry these. |
burton73 |
Jan 18 2010, 05:16 PM
burton73 Group: Members Posts: 3,692 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Scott,
My part number is 901.108.321.OR it was from an early S on my 2.5 69S The size is 41mm over 38mm on a low dollar bullet loading plastic gauge. I had early 69 ported S Heads that I sold to Mark and I am going to be running fresh 76 S heads. Bob |
Lo-Fi Version | Time is now: 26th December 2024 - 04:41 AM |
