> Install Thread on 911 Suspension Swap?, Looking for a build or install thread
Larouex
post Jan 21 2010, 02:38 PM
Larouex
Apologies as I am sure this has been documented, but I could not dig it up in search...
I am looking for a documented thread on installing a 911 front end swap into the 914. I have a 1986 911 front end and I am now preparing to install it.
Thanks in advance,
Larouex
914Sixer
post Jan 21 2010, 03:12 PM
Bolts straight up. Depending on how you have it at this point, up can roll the old out and bolt up the 911 up in same way you take out the old. Are you looking for a step by step procedure?
tat2dphreak
post Jan 21 2010, 03:22 PM
stoya, stoya, stoya
installation is the reverse of removal, as they say.
Larouex
post Jan 21 2010, 03:30 PM
Larouex
I was just checking if anyone had documented it yet. I also have a couple extra/new pieces like the aluminum cross bar and a big, thick sway bar (I assume).
Otherwise I will document what I learn...
Larouex
SLITS
post Jan 21 2010, 03:41 PM
"This Utah shit is HARSH!"
Sounds like you have an SC front end. It's still a bolt for bolt exchange with the worst part being aligning the splines on the steering gear. Your 914 MC/Rack cover will not fit.
The big sway bar is the underbody swaybar. You should have hoops on your A arms with rubber bushings in them. The ends of the bar go in those.
The aluminum crossbar just replaces the steel one.
post Jan 21 2010, 04:26 PM
Resident German
And don't forget the tabs that hold the back of the cross member to the body. They mount to the same spot as the mounts for the underbody sway bar.
The steel cross member has those tabs welded on, but on the alu member, they're removable. You need them!
(IMG:style_emoticons/default/smash.gif) Andy
- Lo-Fi Version Time is now: 26th December 2024 - 12:35 PM
