13 Pages V « < 5 6 7 8 9 > »
> The restoration begins!
dlee6204
post Apr 15 2012, 09:12 PM
Post #121
Howdy
Got some work done on the doors. The passenger door had some dents and one small bit of rust. The driver's side had more rust though. Both doors though had large oil-canning on the bottom half. Possibly from the heat of powder coating. I got both doors roughed back into shape but they will need a skim coat of filler.
After some heat and hammer and dolly work
dlee6204
post Apr 15 2012, 09:14 PM
Post #122
Howdy
One small bit of rust... (IMG:style_emoticons/default/welder.gif)
dlee6204
post Apr 15 2012, 09:23 PM
Post #123
Howdy
And the driver's door... the 'fun' door (IMG:style_emoticons/default/dry.gif)
I started by cutting out the bottom channel completely.
I then cut out a strip of some 20 gage steel
Made a 90 degree bend
And used a steel block to form the U-shape
dlee6204
post Apr 15 2012, 09:28 PM
Post #124
Howdy
Voila!
I welded it in! I smoothed over the welds and its now good to go.
dlee6204
post Apr 15 2012, 09:33 PM
Post #125
Howdy
More oil canning...
993inNC
post Apr 16 2012, 07:36 AM
Post #126
(IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif)
Dude, really, that is very cool! And the bottom edge of the door didn't warp with all that welding? I never even thought about cutting all of that out, just thought we'd fill it in.
Great work......
FourBlades
post Apr 16 2012, 10:32 AM
Post #127
From Wreck to Rockin
Nice repair work!
John
dlee6204
post May 21 2012, 07:34 AM
Post #128
Howdy
dlee6204
post May 21 2012, 07:42 AM
Post #129
Howdy
Lots of tedious work has been happening... I have been focussing on finishing the bodywork for the doors and lids. I started off by sanding everything, applying an epoxy primer over any bare metal areas, and then adding filler over that. This is followed by several stages of high build primer and block sanding. They have their final stage of primer and after I finish the rest of the car, I will wet sand everything down in prep for paint. I'm not going to paint it, Chris will find someone else to do that. (IMG:style_emoticons/default/smile.gif)
dlee6204
post May 21 2012, 07:46 AM
Post #130
Howdy
I also started working on prepping the rest of the car. I sanded the underside of the floorpan and applied some epoxy. I will add seam sealer and then apply a second coat.
dlee6204
post May 21 2012, 09:05 AM
Post #131
Howdy
All sealed up (IMG:style_emoticons/default/smile.gif)
Cairo94507
post May 21 2012, 03:08 PM
Post #132
Michael
Wow (IMG:style_emoticons/default/w00t.gif) That is some serious work and nicely done. Love watching the progress of the build.
speed metal army
post May 21 2012, 11:30 PM
Post #133
Waiting for the rain to stop...
QUOTE(Cairo94507 @ May 21 2012, 02:08 PM) *
No sh!t!!!!seriously, crazy nice work and dedication. Hats off. (IMG:style_emoticons/default/aktion035.gif)
saigon71
post May 22 2012, 06:11 AM
Post #134
Impressive work...especially that door channel piece.
Keep it up! (IMG:style_emoticons/default/beerchug.gif)
dlee6204
post May 22 2012, 08:55 AM
Post #135
Howdy
Thanks guys. (IMG:style_emoticons/default/beerchug.gif)
The underside of the floorpan is pretty much done.
arkitect
post May 22 2012, 09:06 AM
Post #136
Very talented repairs...it will be like new after you are done.
Dave
993inNC
post May 22 2012, 09:08 AM
Post #137
Are we spraying the entire car that white epoxy Doug? That white will go a long way to helping the factory yellow really pop!
Work looks great from here BTW (IMG:style_emoticons/default/pray.gif)
dlee6204
post May 22 2012, 10:38 AM
Post #138
Howdy
Chris, ill try to give you a call tonight. There's a few small things we need to discuss.
993inNC
post May 22 2012, 04:25 PM
Post #139
Ooo that doesn't sound good!
dlee6204
post May 22 2012, 04:32 PM
Post #140
Howdy
(IMG:style_emoticons/default/laugh.gif) I said SMALL stuff
- Lo-Fi Version Time is now: 25th December 2024 - 02:32 AM
