13 Pages V « < 3 4 5 6 7 > »
> The restoration begins!
dlee6204
post Jan 3 2012, 07:30 PM
Post #81
Howdy
QUOTE(993inNC @ Jan 3 2012, 07:36 PM) *
HOLY CRAP (IMG:style_emoticons/default/w00t.gif)
You've been busy (disregard the first half of my email!) Looks great, I may have to start working on cleaning up the suspension parts. You won't be much longer at that rate and I haven't even started getting ready for a rolling chassis.
Yeah, get to work (IMG:style_emoticons/default/poke.gif)
993inNC
post Jan 4 2012, 06:39 AM
Post #82
Yes Sir (IMG:style_emoticons/default/pray.gif)
dlee6204
post Jan 6 2012, 03:19 PM
Post #83
Howdy
Update:
dlee6204
post Jan 21 2012, 08:56 PM
Post #84
Howdy
My welder broke last weekend so I haven't made as much progress as I would have liked. I got a new welder am back in business. I received a package this week from Restoration Design so I was able to get some work done today. (IMG:style_emoticons/default/smile.gif)
More to come...
saigon71
post Jan 21 2012, 10:05 PM
Post #85
Awesome work! (IMG:style_emoticons/default/beerchug.gif)
dlee6204
post Jan 21 2012, 10:32 PM
Post #86
Howdy
QUOTE(saigon71 @ Jan 21 2012, 11:05 PM) *
I used your thread to find the correct placement of the new tray! (IMG:style_emoticons/default/beerchug.gif)
dlee6204
post Feb 4 2012, 03:49 PM
Post #87
Howdy
Got some more work done today. I got the jack points installed on both sides. The sub-metal needed to be replaced before I could weld in the new pieces so it took some time.
I cut out a small piece from the door jamb to gain better access to the top.
dlee6204
post Feb 4 2012, 03:51 PM
Post #88
Howdy
The story was the same for the other side...
Germancar-Junkie
post Feb 4 2012, 06:57 PM
Post #89
Man pedals aren't just for men
Ohhhhh, so that's what a long is supposed to look like! (IMG:style_emoticons/default/drooley.gif) I didn't recognize it without the brown holey stuff??? (IMG:style_emoticons/default/huh.gif)
dlee6204
post Feb 5 2012, 09:31 PM
Post #90
Howdy
I got the seat hinges in today (IMG:style_emoticons/default/smile.gif)
dlee6204
post Feb 5 2012, 09:37 PM
Post #91
Howdy
I also spent quite a bit of time prepping the replacement rear fender. There was plenty of extra meat around the edges from where it was cut off the donor car that I had to remove. Just a little more trimming and it will be ready to go back on.
saigon71
post Feb 5 2012, 10:34 PM
Post #92
Lookin good man!
Like the idea of cutting a flat access panel in the jamb to get at the top of the jackpost.
dlee6204
post Feb 23 2012, 08:52 PM
Post #93
Howdy
Update:
I've been working on a lot of little things lately. The front weatherstrip channel needed a little work so I took care of that.
dlee6204
post Feb 23 2012, 08:58 PM
Post #94
Howdy
The front trunk floor also has some thin metal with small pinholes. Welding them up wasn't an option so I fabricated and replaced a small section.
dlee6204
post Feb 23 2012, 09:12 PM
Post #95
Howdy
I did some work on the lower firewall too.
Also installed the front donuts.
I still have one small piece of the lower firewall to replace on the driver's side and then the jacking triangle and then I will be done working underneath the car. I will rotate the car and begin working on the exterior bodywork. I already spent some time on bodywork but am waiting to finish some of it before I post. (IMG:style_emoticons/default/smile.gif)
dlee6204
post Feb 23 2012, 09:14 PM
Post #96
Howdy
Oh and who says there aren't enough spot welds on a 914... (IMG:style_emoticons/default/blink.gif)
993inNC
post Feb 24 2012, 04:54 PM
Post #97
looks great Doug! Is the rust on the pass lower fw flash rust from grinding away the powder coating? It's not embedded rust under the coating is it?
dlee6204
post Feb 24 2012, 09:08 PM
Post #98
Howdy
QUOTE(993inNC @ Feb 24 2012, 05:54 PM) *
Post 95, picture 2? That's rust that was under some of the seam sealer. That whole lower edge though was replaced.
993inNC
post Feb 24 2012, 10:03 PM
Post #99
Cool, what's the other side look like? Hey BTW did you ever get that ground bolt back in on the driver's side wall just above the engine tray release tube?
dlee6204
post Feb 24 2012, 10:08 PM
Post #100
Howdy
No I keep remembering I need to do that and then I forgot to put it on the list. (IMG:style_emoticons/default/laugh.gif) Consider it done! (IMG:style_emoticons/default/beerchug.gif)
83 User(s) are reading this topic (83 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th December 2024 - 02:08 PM
