turnaround89 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest ![]() |
Found a body shop in my area with a celette bench, made a call and the owner said that fixing the car wouldn't wouldn't happen for under 5000, more towards 10000....im not paying that kind of money to fix a 3000 car, no matter the sentimental value i have in it. Time to find a shell or fix what i got.
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,515 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Found a body shop in my area with a celette bench, made a call and the owner said that fixing the car wouldn't wouldn't happen for under 5000, more towards 10000....im not paying that kind of money to fix a 3000 car, no matter the sentimental value i have in it. Time to find a shell or fix what i got. That's pure bullshit. They just don't want to deal with it. I am working on tracking down a Cellette bench in town here. I just spoke with a guy that used to own one. He sold it to another shop here in town. I have a call into them now. (small shop with a answering machine) I placed a call to the Cellette rep and left him a voice mail as well. What a bunch of crap! BTW, Fixture rental used to be 300.00- 450.00 shipped. |
rick 918-S |
does the place doing the chassis alignment rent the fixtures or is that something i have to locate? I'd just call this guy. I'm sure he can tell you which shop in your area can bench your car. Greg Fritz Sales and Technical Support 630-396-6100 ext 6170 Office 630-495-4078 Fax www.celette-na.com I had a conversation with a Cellette rep. He is emailing info about the fixture availability, location and cost. I can either get you hooked up with the local shop or if they are tired of the old Cellette collecting dust in the corner I may just purchase the thing. This will happen whether you ever fix your car or not. I have The raspberry car with a missing front clip and Sandy's I'm picking up in Cali in like two weeks. It took a hit to the front. Your inquiry just prompted me to do something I have been wanting to do for a long time anyway. |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,711 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Your inquiry just prompted me to do something I have been wanting to do for a long time anyway. If you do, don't forget to make a 'backup copy' of the fixtures ... (IMG:style_emoticons/default/shades.gif) Andy |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 119,389 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
Turnaround, What happened to the pictures you were going to post?
turnaround89 |
the pictures were on an external hard drive which makes a weird clicking noise when it starts up, the computer doesn't recognize it anymore...been going on for a couple weeks or so, my cousin is taking a look at...hopefully he can get the files off of it.
Anyway, the guy i talked to that has the celette bench has worked on multiple 911's, and seemed to know what he was talking about. His idea was to pull the whole car apart again and leave it on the frame rack and then reweld all the stuff back into the car. Lots of time right there. I made the floor pans and inner longs myself, and i really don't want to have to completely undo everything i just did. I don't mind cutting slots into the longs, but taking everything back out. no thanks |
rick 918-S |
the pictures were on an external hard drive which makes a weird clicking noise when it starts up, the computer doesn't recognize it anymore...been going on for a couple weeks or so, my cousin is taking a look at...hopefully he can get the files off of it. Anyway, the guy i talked to that has the celette bench has worked on multiple 911's, and seemed to know what he was talking about. His idea was to pull the whole car apart again and leave it on the frame rack and then reweld all the stuff back into the car. Lots of time right there. I made the floor pans and inner longs myself, and i really don't want to have to completely undo everything i just did. I don't mind cutting slots into the longs, but taking everything back out. no thanks No need to rip apart all your work. It doesn't matter that you made your own pans and inner longs. The Cellette works off the suspension pickup points not the floor or longs. I suspect the cowl is leaning back which would cause the doors to sag at the rear. This would put the front most suspension pickup points of the car high and out of line. Should be able to bolt on the check sets (four center most fixtures) and find the issue. I would say it would be a matter of vertical cuts through your longs, check the upper body diamensions and adjust the car. |
turnaround89 |
right now were beginning to pull apart portions of the car, to get correct measurements. the front suspension is gonna get pulled off today, and well keep measuring to see where the car is off.
rick 918-S |
I heard back from the shop. I really couldn't read the guy. I asked him if he was interested in selling the bench. He said he would think about it. I asked him if he was interested in fixing your car. He said he would think about it.
Ok, but he did tell me that the local frame and axle guy has the second design Cellette bench that only requires the top section of the redsigned fixtures, It's the MZ model. Shipping cost for the fixtures are less because the tops come in a suitcase not a friggin shipping crate. The only thing is there may not be fixtures for the older chassis'. I'm still checking. |
(IMG:style_emoticons/default/WTF.gif) I don't get it... Think about it ... (IMG:style_emoticons/default/biggrin.gif) |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,914 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
I braced the chassis, but obviously not enough. I lined the doors up properly, had the gaps correct, and then put the braces in. I took the braces out today, and went to test fit the passenger door and it won't even come close to shutting. the door lock does not line up, i tried adjusting the hinges but had no luck. The things are way off....any one have a fix? I really don't want to buy a tub because i just put a ton of work into this one. If it comes down to buying a tub, i guess thats what ill have to do, but i really would like to avoid that. I know that it is a long way but our man Kirk could get your car perfectly straight again in no more than a days work and 400 bucks. He is a master |
turnaround89 |
Id have to tow the car down to georgia, and that would be a lot....thats not a bad idea. I would bring the car down as a bare chassis, no motor, trans or suspension. Thats what were working on now...we accidentally broke one of the sway bar bolts head off. I may be able to pull that off, my brother lives in athens, i could just make a trip to see him and take the car to you guys as well. What if kirk would have to cut the car, would that add to the expense?
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Rick, how about getting access to the one you know of long anough to get some god pictures and measurements. There isn;t that much there, and a bench could easily be replicated by you, or any one of us with the tools and experience. I know, I for one would have enough use to build one. I would imagine Perry might be interested too (IMG:style_emoticons/default/confused24.gif) The the only issue is the fixtures........ (IMG:style_emoticons/default/idea.gif)
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Rick, how about getting access to the one you know of long anough to get some god pictures and measurements. There isn;t that much there, and a bench could easily be replicated by you, or any one of us with the tools and experience. I know, I for one would have enough use to build one. I would imagine Perry might be interested too (IMG:style_emoticons/default/confused24.gif) The the only issue is the fixtures........ (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/agree.gif) I bet Andy could get some detailed pics of the bare bench. Rich |
rick 918-S |
(IMG:style_emoticons/default/cool.gif)--><div class='quotetop'>QUOTE(scotty b @ Feb 23 2010, 06:57 PM)
![]() Rick, how about getting access to the one you know of long anough to get some god pictures and measurements. There isn;t that much there, and a bench could easily be replicated by you, or any one of us with the tools and experience. I know, I for one would have enough use to build one. I would imagine Perry might be interested too (IMG:style_emoticons/default/confused24.gif) The the only issue is the fixtures........ (IMG:style_emoticons/default/idea.gif) [/quote] Here's what I know about the bench. The early Celettes have a machined deck like decking a cylinder head. The fixtures bolt to the cross beams. The early fixtures are like the ones in Sir Andy's photos. The later model Celettes have a standard upright fixture set that is part of the bench when you purchase it. The fixtures bolt to the top of the uprights. This only requires a large suit case of tops not and entire crate of parts. That was the drawback of the old bench was shipping the fixtures around. I know there are 914 fixtures for the early bench. I haven't verified ther are fixtures for the redsigned bench. Sorry for hi-jacking your thread. I should have started a new one. |
shaggy |
mechanic/welder/fabricator ![]() ![]() ![]() Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None ![]() |
how thick were the plates you welded on?
regardless its going to take a great deal of force to bend the chassis back. having worked on 914s structurally i dont think there is a good way to do this. by bending the chassis with the plates intact you are only stretching(weakening) the structure somewhere else. you best bet would be to slash cut your plates. if you can do that that will relieve the stress on the chassis then see how much(if any) the chassis corrects. if it dosent correct enough then id think about straightening and welding the plates while the chassis is on the fixture. you said you replaced part of the body structure prior to plating correct? when you set the door gaps were the adjustments at their limits? what welder and settings did you use to weld the plates on? if this is an AX car or something you might as well cage it now and not deal with this problem again later. did you weld the car on the ground? or on a lift? with or without suspension? -jim |
rick 918-S |
I'm near a deal on the Celette. (IMG:style_emoticons/default/shades.gif)
turnaround89 |
so heres the plan that we finally came up with. My dad and i are going to try and fix the problem ourselves...we figured ive put enough work into it so far to at least give this a shot. if we can't fix it, then we will resort to a frame rack, and since rick is getting closer to a deal with the celette i would take it up there. If he does not make the deal, i would haul it to AA, sooner or later my car will be straight again.
Next week were gonna start trying to fix the car. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) |
rick 918-S |
so heres the plan that we finally came up with. My dad and i are going to try and fix the problem ourselves...we figured ive put enough work into it so far to at least give this a shot. if we can't fix it, then we will resort to a frame rack, and since rick is getting closer to a deal with the celette i would take it up there. If he does not make the deal, i would haul it to AA, sooner or later my car will be straight again. Next week were gonna start trying to fix the car. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) Use the chassis measurements listed here on the site. Measure everything twice and take your time. If you screw it up your no further off than you are now. Just be sure you check the car to be sure you know of the rear section is tipped forward or if the cowl is tipped back before you start trying to move things around. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Rick , I hope you get a bench ,
AArron @ Fat Six has a bench and the rental center for fixtures is in illinios. http://flat6.com/?page_id=11 Attached image(s) ![]() |
Lo-Fi Version | Time is now: 28th June 2024 - 06:34 PM |
