I Love my Soda Blaster..., ...is that wrong? |
pete |
Mar 21 2011, 08:26 AM
Member Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States |
I made the simple one from info on this forum. Did a great job on my trans. Any ideas on how to contain the dust though? I did the trans on my driveway and positioned an industrial fan behind me. My back yard was white by the time I was done.
Eric_Shea |
Mar 21 2011, 08:40 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Water? (IMG:style_emoticons/default/confused24.gif)
Just a heads up gang. This is commercial soda not Arm & Hammer stuff. While you can get a simple gun and shoot Arm & Hammer (good for carbs and small parts), the commercial stuff comes in 50lb bags and you sometimes pay by the bag. The commercial soda has the consistency of large grained sand. My car was under $600 because we had glass hoods and we DA'd all of the flat surfaces prior to bringing it in. We used soda on both trunks, the engine compartment and the underside. (IMG:http://www.914world.com/bbs2/uploads_offsite/a8.sphotos.ak.fbcdn.net-1110-1300718427.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/a1.sphotos.ak.fbcdn.net-1110-1300718428.2.jpg) |
Krieger |
Mar 21 2011, 09:15 AM
Advanced Member Group: Members Posts: 4,771 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Are you kidding...no faceshield?
Mar 21 2011, 09:24 AM
Custom Member Group: Members Posts: 24,688 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
After I used my soda cabinet on a set of carbs the first thought I had was, "where have you been my whole life"
So no, its not wrong imho Rich |
Eric_Shea |
Mar 21 2011, 09:52 AM
QUOTE Are you kidding...no faceshield? What you see is what you get. After about an hour I asked him if he wanted to use my saftey glasses. His eyes were bleeding. |
gothspeed |
Mar 21 2011, 02:28 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Where does one get the 'soda' .... (IMG:style_emoticons/default/unsure.gif) ??
Smitty911 |
Mar 21 2011, 03:21 PM
Member Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California |
ldsgeek |
Mar 21 2011, 08:01 PM
Member Group: Members Posts: 155 Joined: 27-June 10 From: New Hampshire Member No.: 11,885 Region Association: None |
Or everybody's favorite junk shop Harbor Freight |
nathansnathan |
Mar 22 2011, 12:29 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
I was worried about paint/ primer adhesion with soda blasting as I'd read about the chalky residue that it leaves - some say just soap and water will take it off, some say add vineger to neutralize the ph, others talk about the need for elbow grease. The thought of my paint falling off led me to getting glass beads instead for my project. For engines/ carbs, the soda seems the way to go though as it is water soluble.
Eric_Shea |
Mar 22 2011, 12:35 PM
My car got a vinegar bath. Pain came out perfect.
rgalla9146 |
May 10 2013, 07:21 AM
Advanced Member Group: Members Posts: 4,673 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
d914 |
May 10 2013, 07:27 AM
Advanced Member Group: Members Posts: 2,345 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
No, paint.....
ConeDodger |
May 10 2013, 09:04 AM
Apex killer! Group: Members Posts: 23,868 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
$600 - $1,000 depending on the blaster. Does it remove rust ? No. It only removes paint. You need to switch to sand to take out the rust areas. They say that soda blasting can take the paper off a cigarette filter without harming the filter. I switched my cabinet to soda... (IMG:style_emoticons/default/wub.gif) |
Eric_Shea |
May 10 2013, 09:06 AM
$600 - $1,000 depending on the blaster. Does it remove rust ? (IMG:style_emoticons/default/agree.gif) Just paint. It leaves the metal as new as the day it was born. There were a few spots around the engine shelf that needed rust repair and that was spot blasted with a sand blaster and replaced with new metal. Soda even left the factory seam sealer in place which is what we wanted. |
Lo-Fi Version | Time is now: 8th January 2025 - 11:46 PM |
