Hot Spark = No Spark |
pyolet |
Mar 10 2010, 12:20 AM
Newbie Group: Members Posts: 11 Joined: 3-December 09 From: Helena, MT Member No.: 11,093 Region Association: Rocky Mountains |
Guess I picked Hot Spark 'cause I wanted some new technology, it was cheap on Ebay, and it wasn't Pertronix.
It worked fine for about 2 minutes run time. Then Hot Spark became No Spark. I pulled my engine to clean (recent purchase) after initial Hot Spark successful install, and once engine was reinstalled, I only got intermittent fire for a few minutes, then nada. After confirming all wiring wasn't queeped, I yanked the No Spark and put the points back in, and she runs perfectly. Got an extra set of points to throw in the glove box and threw the Hot Spark in the trash. Hot Spark is not reliable IMO and not ready for the long haul.....my $.02. No I never reversed polarity and my coil is fine. It's just Chinese garbage and thank the gods I didn't get stuck out in the middle of nowhere..... Woody. |
underthetire |
Mar 10 2010, 12:33 AM
Guess I picked Hot Spark 'cause I wanted some new technology, it was cheap on Ebay, and it wasn't Pertronix. It worked fine for about 2 minutes run time. Then Hot Spark became No Spark. I pulled my engine to clean (recent purchase) after initial Hot Spark successful install, and once engine was reinstalled, I only got intermittent fire for a few minutes, then nada. After confirming all wiring wasn't queeped, I yanked the No Spark and put the points back in, and she runs perfectly. Got an extra set of points to throw in the glove box and threw the Hot Spark in the trash. Hot Spark is not reliable IMO and not ready for the long haul.....my $.02. No I never reversed polarity and my coil is fine. It's just Chinese garbage and thank the gods I didn't get stuck out in the middle of nowhere..... Woody. I never had an issue with mine, till my small fire. The company will stand behind the product, as they have a 3 year warranty. Call them in texas and talk to them before you trash a good product on the internet. You want chinese garbage, that would be the Empi one. Also, make sure the braided ground cable is in good shape inside the dizzy. They use that for signal noise reduction. |
Lo-Fi Version | Time is now: 2nd January 2025 - 04:10 PM |
