wayne1234 |
Member ![]() ![]() Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None ![]() |
So I took off the hearter parts of my parts car and cleaned them all up and painted everything did the drivers side and decided to try it out..... (IMG:style_emoticons/default/sad.gif) tempeture was about 60 outside last night and after running a few minutes the vent was putting out a weak 72 hardley any air movement. the flapper bos is working and in good condition and the dual fan blows out a fair amount of air, but it doesnt seem to make it up front... on chilly mornings and evenings I want some heat and defrost... this wont cut it in my opinion... what else has been done??? I had a crazy idea of a power inverter, and hair dryers behind the speakers, anyone done anything like this??? I have seen 12 volt hair dryers... what else has been done????? or what am I doing wrong ???? I know I have read many complaints about the heat but I had no idea it was that bad...
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Give it up and get headers. (IMG:style_emoticons/default/smile.gif) heat is over rated.
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
Wayne -
A properly operating 914 heat system should toast you out, so something is wrong with yours. Yours is probably doing a great job of heating the outside air! (IMG:style_emoticons/default/biggrin.gif) Could be any combo of: leaky or obstructed hoses & ducts & connections, rusted out heat exchangers, branch & J tubes, bad fan(s), cables & flappers not fully operating/slipping, etc., etc. Just got to check it all out one by one,maybe starting with the obvious stuff like a torn hoses - which are easy & not too expensive to replace (except the ones behind the rockers - more work there). Time to go fishin' around the 914! (IMG:style_emoticons/default/shades.gif) While you're only 60 today - & we're that or less in SoCal so far this week - lest you think I never had it in winter weather - I used it as my DD 12/75 - 5/85 & regularly went snow skiing in the mountains with sub-zero temps! Heck - I could keep the cockpit toasty with the top off going up to Park City UT, Lake Tahoe & Mammoth CA! I always liked that you could meter how much hot went to the upper vents & your face, vs. down low at your feet - so you didn't get that "sleepy time" from warm air in the face on a long drive! (IMG:style_emoticons/default/smile.gif) Good Luck Bud! (IMG:style_emoticons/default/beerchug.gif) |
Triaddave |
Member ![]() ![]() Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 ![]() |
Mice love to nest in our cars, check to tunnels. did you leave a cleaning rag somewhere? Miami is a nice place to live too.
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
I put a header on, so no heat now, but it used to get real hot. I'm working on a electric heater to go under the speaker grills myself. Using two of these for the guts.
http://www.harborfreight.com/cpi/ctaf/disp...temnumber=96144 They actually get fairly warm, but I don't think they will get the inside too warm unless its sealed up good. |
siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
I agree. Stock 914 heat works REALLY well... -Steve |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
> A properly operating 914 heat system should toast you out, so something is wrong with yours. I agree. Stock 914 heat works REALLY well... (IMG:style_emoticons/default/agree.gif) If in good working order, the stock system works great. Even better with the SSI heat exchangers. This should be warm and toasty. If it's not, something isn't right. (IMG:style_emoticons/default/popcorn[1].gif) Andy |
wayne1234 |
I know all the rear piper are clean and clear.. the flapper boxes valve move with the inside lever. there isd minimal crushing behind the speakers from the PO... I took apart the rear fan and cleaned and painted it it moves alot of air.. the exchangers seem to be loos onthe exhaust so maybe thats where I'm loosing the air and I will check air flow in the longs witha shop vac in the blower configuration.. I just wanted to make sure I wasent chasing a ghost... I will let you guys know later tonight Thanks
zx-niner |
Member ![]() ![]() Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California ![]() |
That might be right if you were measuring the temperature with your car idling in the driveway. If that's the case it should be better when you are driving. The exhaust pipes should get hotter, transferring more heat. And you'll get more air movement from the engine cooling fan overriding the too weak heater fan.
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
I'm not that sophisticated. In the winter, I block off a little of my front cooler and vent it to the stock heater points in the front trunk. That gives me defrost heat and does a surprisingly good job of heating the car. It takes me about 20 minutes to either install it, or take it and it's hoses totally out of the car and block off the heater points.
It's nothing as good as the original system mind you, but my exhaust plumbing is sure a lot simpler. Those work great. Good luck |
wayne1234 |
By the way what turns on the rear fan??? I have it jerry rigged rught now???
By the way what turns on the rear fan??? I have it jerry rigged rught now??? The heater level on the floor near the shifter ... (IMG:style_emoticons/default/shades.gif) Andy |
wayne1234 |
ok there is a green wire in the lever it looks like it switches ground... I have a green wire near the dizzy which I originally thought was the fan according to how I was reading the wiring diagram... I tested it it has no power regardless of lever position , so there must be a relay.. that the lever green wire triggers, I must be missing it it when I'm looking at my diagram.. is it on the the relay board?? I slid in a couple of relays in my empty spots. I dont see a breakdown in the diagram of the relay board and what relays do what,,, I'm sure I am overlooking something
Kirmizi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None ![]() |
I believe the auxillary fan runs off the same fuse on the relay board as the fuel pump. IIRC it's the rear fuse. Does the blower motor work if you apply 12v?
Mike |
wayne1234 |
yep blower works I had it directly to battery for testing... ok found the wiring diagram on the board and the relay clicks if I pull the lever... but I think I should have power at terminal #11 I don't???? if I pull the relay there is power on the socket.. and the relay clicks but no power to terminal 11 ... What am I missing? (IMG:style_emoticons/default/wacko.gif)
Kirmizi |
Doh! My bad, just read your fan works...
I drive mine regularly with the temps in the twenties and although it takes awhile to warm up, I'll get decent heat in the cabin. Mike |
Kirmizi |
Have you tried swapping out the relay with a known good one?
The rearmost relay and rear fuse are part of the blower motor circuit. Mike |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
That might be right if you were measuring the temperature with your car idling in the driveway. If that's the case it should be better when you are driving. The exhaust pipes should get hotter, transferring more heat. And you'll get more air movement from the engine cooling fan overriding the too weak heater fan. on steves note... AT IDLE if your missing the small lower aluminum flaps -or they are stuck open, you will push the air meant for the cabin into the doghouse(?). without the proper operation of those flaps the direction from the (auxilary) blower fan won't end up in the cab. higher rpm should overide the aux blower though mike |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
Mine is beyond warm and edging toward too hot when full open to a pre-fan on setting.
Check you tubes up front. I have found that a shop-vac on blowing mode can get junk out of the long tubes. Also check to see that the vents up-front are working. Depending on the year model you may need a jumper on the relay board that jumpers the fan. It's the green jumper wire in my photo below. Ignore the writing it was from another post. ![]() |
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
Got to be something wrong with your system. I only have half of mine hooked up and when I showed up at the Buttercup build I was in a t-shirt and sweating when I got out of the car. Wore just a t-shirt on the way home too even through the snow.
Lo-Fi Version | Time is now: 25th June 2024 - 06:00 PM |
