Polishing Window Trim |
yeahmag |
Mar 31 2010, 12:36 PM
Advanced Member Group: Members Posts: 2,435 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I got some used AL windshield trim and need to polish it up. The anodizing is badly scratched and my local plater will want about $80 to fix it. I've read conflicting things about how to strip the anodizing and how to polish it there after.
Anybody have any real world advise? -Aaron |
Mar 31 2010, 06:02 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Easy off takes off anodizing.
From there you probably want to sand it from 600 or higher up to 1500, then use progressive buffing compound on a wheel buffer. Rich |
Rand |
Mar 31 2010, 06:08 PM
You polish something on a 914? Eww. Remove, eliminate, scuff... anything but polish! (IMG:style_emoticons/default/happy11.gif)
Tom_T |
Mar 31 2010, 06:25 PM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Easy off takes off anodizing. From there you probably want to sand it from 600 or higher up to 1500, then use progressive buffing compound on a wheel buffer. Rich IIRC there's a tech article on this very subject on the Pelican site, & that they start with 1000 or 1500, then go to 2000, then chrome polish. The grit takes off most of the anodized layer (pretty thin effect layer), as you're smoothing out the scratches. Go look on the Bird site for the step by step & pix! Also there was one topic posted awhile back under O&H on how some of the CW's get theirs all purdy! They also have a wheel polishing tech article at the bird site. |
Pat Garvey |
Mar 31 2010, 06:56 PM
I got some used AL windshield trim and need to polish it up. The anodizing is badly scratched and my local plater will want about $80 to fix it. I've read conflicting things about how to strip the anodizing and how to polish it there after. Anybody have any real world advise? -Aaron Do it! Let the plater do the hard work. It isn't the anodizing that's "badly scratched" -it's the aluminum below. Once the anodizing( a very fine coating) is compromised the only option is to refinish. You can polish like a bat's ass but it will be useless if it isn't re-anodzed. And, the plater should have quoted you for polishing before re-anodizing. You shouldn't need to do anything thereafter. A little ossasional wax wouldn't hurt, but never take any abrasive compounds to it. EVER! Pat |
Lo-Fi Version | Time is now: 26th September 2024 - 05:34 PM |
