CptTripps |
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,585 Joined: 26-December 04 From: Tuscaloosa, AL and Akron, OH Member No.: 3,342 Region Association: Upper MidWest ![]() |
I have 3" on there now, and will be putting 3.5" on. So I think these bearings are for the 3", and not the 3.5" that I have. Right?
I couldn't find these bearings listed on any of the parts websites we all use. When I pulled the hubs off of the 3" struts, they slit right off. I couldn't get these bearings on the 3". If anyone can follow all of that...I'll be impressed! |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,299 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
The spindles themselves are all the same on the 911's. Just the threaded end changes so those are good for either.
tomeric914 |
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,265 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States ![]() ![]() |
Yup. 914 spindles are smaller all around. Smaller inner and outer bearings etc. Totally untrue. The 911 and 914 spindle diameters where the bearings ride are IDENTICAL in diameter. FYI... a few years ago I did some digging with a local bearing seller. We found two tapered roller bearings with the proper OD for a 911 hub, and the proper ID for a 914/4 spindle. We also found the proper seal. There are no special bearings. To put 911 hubs on a 914, you need the 911 bearings, seals and possibly the inner collar that the seal rides on. I've had two sets of 914 struts with 911 hubs and just confirmed that the bearings are an exact fit between 914 and 911 spindles. |
bulitt |
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States ![]() |
So, all you need to convert a four lug 914 strut to 5 lug is a 911 hub with bearings that fit the 914 spindle?
tomeric914 |
bulitt |
So, all you need to convert a four lug 914 strut to 5 lug is a 911 hub with bearings that fit the 914 spindle? Seriously? Read my post above again. The answer is in RED. Seriously? Then the classic thread needs to be revised to inform potential converters to this option. Instead of everyone replacing their entire front suspension with a 911 one? |
tomeric914 |
So, all you need to convert a four lug 914 strut to 5 lug is a 911 hub with bearings that fit the 914 spindle? Seriously? Read my post above again. The answer is in RED. Seriously? Then the classic thread needs to be revised to inform potential converters to this option. Instead of everyone replacing their entire front suspension with a 911 one. Exactly. This "classic" thread was wrong from the start. Eric will need to update the first post of this thread. If I were an admin, I would have done it by now. |
Eric_Shea |
What is this? Amateur hour?
Ummm put'th thy crack'th pipe down'th. It "was" an otherwise "accurate" "classic" thread. (IMG:style_emoticons/default/dry.gif) Smallish 914 inner bearing measurement: (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-a-pao.xx.fbcdn.net-1110-1395175770.1.jpg) Not as smallish 911 inner bearing race measurement: (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-e-a.akamaihd.net-1110-1395175771.2.jpg) |
Eric_Shea |
QUOTE Totally untrue. The 911 and 914 spindle diameters where the bearings ride are IDENTICAL in diameter. (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/alfred.gif) Good luck with that. Perhaps a video will help. 911 inner wheel bearing on a 914 spindle: https://www.youtube.com/watch?v=4Xu_7J58IEU |
Eric_Shea |
So, all you need to convert a four lug 914 strut to 5 lug is a 911 hub with bearings that fit the 914 spindle? Seriously? Read my post above again. The answer is in RED. Seriously? Then the classic thread needs to be revised to inform potential converters to this option. Instead of everyone replacing their entire front suspension with a 911 one. https://www.youtube.com/watch?v=bufTna0WArc |
bulitt |
There you go dealing in facts again! (IMG:style_emoticons/default/dry.gif)
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Well the jury is still out (IMG:style_emoticons/default/dry.gif) First off : Mrs. Hea didn't measure the inside of the 914 race. He measured the midside diameter of the bearing, ( see pic for poof ) but then the inside of the 911 race. suspicious ? yes ! Second : Mrs. Hea did not post his " factual " findings in red, therefore it is still unfounded and more research needs to be done. I'll patiently await some REAL results from Woody or Jake |
bulitt |
Poorly
Measured Bearings (IMG:style_emoticons/default/hide.gif) But hey! feel free to delete any of my posts to return this thread to classic status. Your "how to" threads are a blessing! (IMG:style_emoticons/default/smilie_pokal.gif) |
tomeric914 |
QUOTE Totally untrue. The 911 and 914 spindle diameters where the bearings ride are IDENTICAL in diameter. (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/alfred.gif) Good luck with that. Perhaps a video will help. 911 inner wheel bearing on a 914 spindle: https://www.youtube.com/watch?v=4Xu_7J58IEU I would not have posted my findings without verification first. I took the inner and outer bearings off the 914 model numbered strut/spindle and transferred them directly to the late 911 strut/spindle and they fit exactly with no play. Did 914/6 struts have a 914 part number to them? If so then that explains what I have. The car is not an original 6. |
balljoint |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,001 Joined: 6-April 04 Member No.: 1,897 Region Association: None ![]() |
A few wraps of duct tape will take care of the mismatched diameters. Or grease. Just pack the gap with grease. Problem solved.
Eric_Shea |
Well the jury is still out (IMG:style_emoticons/default/dry.gif) First off : Mrs. Hea didn't measure the inside of the 914 race. He measured the midside diameter of the bearing, ( see pic for poof ) but then the inside of the 911 race. suspicious ? yes ! Second : Mrs. Hea did not post his " factual " findings in red, therefore it is still unfounded and more research needs to be done. I'll patiently await some REAL results from Woody or Jake Dearest Mudslinger, measurements are from the same sections. The 914 bearing is so much smaller the calipers are resting on the "box" (not the bearing like the 911 bearing) skewing the view. If it were as yee suspected, that 914 bearing would be even smaller. Back to yer paint huffing. Hey, this used to be a useful thread (IMG:style_emoticons/default/w00t.gif) |
Eric_Shea |
914-6 struts are the same as 911T struts yet have a 914.341.xxx.xx part number.
You should have verified what an actual 914 strut looks like as well. They are quite different. Love the comments though, caps, quotation marks, red text and all. (IMG:style_emoticons/default/thumb3d.gif) |
MoveQik |
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,654 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region ![]() ![]() |
914-6 struts are the same as 911T struts yet have a 914.341.xxx.xx part number. You should have verified what an actual 914 strut looks like as well. They are quite different. Love the comments though, caps, quotation marks, red text and all. (IMG:style_emoticons/default/thumb3d.gif) So wait...now I am confused. Is this thread incorrect from the get-go as stated in post 67 or was it right all along? And should have I put this in RED? |
tomeric914 |
914-6 struts are the same as 911T struts yet have a 914.341.xxx.xx part number. The actual 914/6 strut part number would be great information to have in this "Classic" thread under option 2. It is not listed on PET. While they look like 911T struts, they aren't. You should have verified what an actual 914 strut looks like as well. They are quite different. I did and apparently only have 914/6 strut housings in my stash. I also used your thread for verification which was missing the information above. Love the comments though, caps, quotation marks, red text and all. (IMG:style_emoticons/default/thumb3d.gif) I love the childish behavior on your part. Keep up the good work. |
Eric_Shea |
Sorry my bad (IMG:style_emoticons/default/blink.gif)
Lo-Fi Version | Time is now: 2nd April 2025 - 11:39 PM |
