914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,190 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
I personally have NEVER used the thing cuz OE Bilstien Jack just seems crappy and usually the jack posts are sketchy at best (IMG:style_emoticons/default/sad.gif)
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Answering this poll makes me realize I don't have a factory jack! (IMG:style_emoticons/default/confused24.gif)
ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
A few months ago I traveled to San Diego to see a movie. After the movie, my car wouldn't start - no fuel pump noise. Since I was parked on a level section of a parking garage, I jacked up the drivers side, found a loose fuel pump wire and fixed it.
It made for a nice ride back to Orange County. As far as I'm concerned, the stock jack is a very reliable jack for emergency use. I would never use it in my garage, but when you're traveling and stuck, it does the job pretty well. Eric Read |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
I use mine at every AX I attend to change to race tires and back. It works great is compact and light weight. Just keep it lubed. Try it on an incline with dirt... (IMG:style_emoticons/default/hissyfit.gif) BZZZZZZZZZZZZZ!!!! - Rob - read the owners manual - level hard surfaces only! Also the opposite front wheel should be chocked/stopped-off F&R. Jacking 101: get to a proper & safe place to change the flat (flat, level & hard surface out of & well away from traffic), chock the opposite front tire F&R, release the E-brake, get the jack in position on a firm/flat surface & in the tube (inspect tube first every time) & just start it up without lifting the tire, break the lug bolts/nuts loose while the tire is still weighted on the ground, then jack up & remove the flat, replace with the spare (forehead top & knees at 70-80 & 200-220 degrees to hold the tire in place for the firs lug always worked for me in the pre-aligning-stud days), hand tighten the lugs, let her down part way to partially re-weight the wheels to tighten up the lugs (star pattern, go to opposite corners rather than all around consecutively), then let 'er down the rest of the way, remove the jack, re-set the E-brake, remove the chocks & stow the flat, jack, etc. & get to a tire store asap to get the flat fixed. I can make a video for you Rob, if you want! (IMG:style_emoticons/default/biggrin.gif) Rich - they're also made for roadside emergencies - NOT shop work - use a proper floor jack for that, which is why there are 4 jacking/lift doughnuts on the underbody. But they're leagues better than the old USA ratchet types of the day!! So long as your jack tubes/supports & longs are good, the Bilstein jacks work fine, but I prefer the 73> screw-type better than the earlier ones. If the jack posts are iffy, then get a compact +/- 2 ton piston jack to carry on/next-to the spare in the front trunk well & use that on the appropriate jack post. Good idea to use a rubber or poly pad on top of the piston to save the doughnuts finish a bit. IMHO the hydraulic piston types are more reliable than the scissors type. I've used both the factory & piston types on mine - about once or twice a year back in the day - sometimes to put the cable chains on the rears when up in the mountains to ski if space was too tight to roll back onto the chains. They work fine & are safe when used properly on a 914 without damaged tubes/longs & never get under the car with them. I'd bet that at least 9 times out of 10 the mishaps noted above were due to either tube/long damage &/or improper use of the jacks - including incomplete insertion into the tube - which the gals hate! (IMG:style_emoticons/default/biggrin.gif) BTW - I voted 1 year anyway, even if it's been 25 since I drove mine. Damn the statisticians & full speed ahead - since a survey/pol can be structured to get any answer you want! (IMG:style_emoticons/default/lol-2.gif) OK - so now I see that 70+% of you have never used theirs, so the garage queens & those missing a stock jack have to be thrown out, & you have to allow us old farts more than a year ago to vote under the "last year category"!!!! (IMG:style_emoticons/default/shades.gif) |
qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
I have a 944 jack for my car. Much more reliable and versatile. (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-419-1272861478.1.jpg) What year 944 jack is this? (IMG:style_emoticons/default/idea.gif) |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
I like the idea of picking up a 944 jack. I have never used my 914 jack. I've restored some to pristine condition though & they sure looked nice sitting in my trunk (IMG:style_emoticons/default/biggrin.gif)
pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
i did it once...
never again... i think it was designed as an afterthought...or perhaps the jack engineer was a little (IMG:style_emoticons/default/drunk.gif) |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
I have a 944 jack for my car. Much more reliable and versatile. (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-419-1272861478.1.jpg) What year 944 jack is this? (IMG:style_emoticons/default/idea.gif) Any . Some of the earlier cars had the same design and spec jack, but it was steel. ANY turbo car or post 85.5 n/a car should have the aluminum I believe. Check E-bay, usually 20,00-30.00 |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
i also did it once (IMG:style_emoticons/default/sad.gif) thats how i discoverd my jack posts are not in the best of condition. i also bent the valence and it remains bent untill today.
floor jack for me |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
My car doesn't have the jack posts so the OE jack is useless. I carry a 944 jack for roadside emergencies.
scotty b |
If a few of you want the 944 jacks, I can ask a local guy that parts 944's. He may have a few sitting around.
arkitect |
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
When I've used mine, it worked great. I should mention that mine looks new and is not a POS; if it were I wouldn't use it in the first place.
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
I used it once many years ago (no choice for that in the poll). It worked fine but I was on asphalt and the only flat I've ever had in that car.
Lo-Fi Version | Time is now: 26th June 2024 - 06:23 AM |
