Another test drive today...., Now my left side lights are not working. |
montoya 73 2.0 |
May 9 2010, 12:14 AM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
Headlights work, fog lights work. The brake lights and the blinkers work on both sides but no running indicators on left side (drivers) front or rear? What say you?
Mike Bellis |
May 9 2010, 12:32 AM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
wiggle the bulbs. replaced mine today with new bulbs and they stopped working. A little wiggle and they came back. Also check and clean the ground behind the headlight bucket.
montoya 73 2.0 |
May 9 2010, 07:57 PM
Well, I tried the wiggle and checking the connections to the fuse box and nothing. Ground wires are fine. I had installed the Engman fuse box awhile back with the "smart" fuses, Well the fuses aren't so smart. I thought I should check the fuses but none were lit up so I checked anyways and yep the left side fuse was blown. I thought those smart fuses were supposed to light up when they blow?
dr914@autoatlanta.com |
May 10 2010, 12:46 PM
914 Guru Group: Members Posts: 8,109 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Lo-Fi Version | Time is now: 22nd December 2024 - 12:33 AM |
