Raspberry 914 build starts |
rick 918-S |
Jun 13 2010, 09:15 PM
Hey nice rack! -Celette Group: Members Posts: 20,817 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Here's another example of the amount of heat this car was exposed to. The engine lid seal turned into a chunk of brittle plastic and shattered and splintered as I tried to remove it. All the rubber has some amount of the same condition.
rick 918-S |
Jun 13 2010, 09:18 PM
I have 2 that same color in spots. I assumed it was a zinc chromate type primer. (IMG:style_emoticons/default/confused24.gif) BTW - that color match looks dead nuts from the pics. Yes, The match is right on with Acrylic Enamel. I haven't checked the $ 100.00 a pint urothane yet. (IMG:style_emoticons/default/screwy.gif) |
jasons |
Jun 13 2010, 10:20 PM
Jackstand Extraordinaire Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Fraise it is, but that is French for strawbery. Somehow the English translation is raspberry, so somewhere it is a mis-translation. Also in factory literature as rose red. Whatever, it is not pink as some computer monitors show. It is a nice rich red. I agree. I think people will be surprised when they see the color in person. My monitor makes the color look pink. I don't know, I've seen a lot of that car in person and my eyes make it look pink. (IMG:style_emoticons/default/biggrin.gif) Actually it will be a color that always looks different depending on light. Its weird to see someone else working on that car. |
carr914 |
Jun 14 2010, 07:26 AM
Racer from Birth Group: Members Posts: 122,475 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
$ 800.00! This is before the reducer/activator! The pint I purchased today was like $ 110.00! ouch! Wow! What makes paint so expensive? At 110.00 a pint that must translates to about a dollar a second of spraying! The Pigments in Red paint are the most expensive out there. And the cheaper they, the more they will sun-fade. Stick a MAACO $99 red painted car out in our Florida Sun for a while and it will be Raspberry in no time. |
rick 918-S |
Jun 18 2010, 07:45 PM
I bought a new tool today. I went to Harbor Freight and picked up a soda blaster. My goal is to strip the interior surfaces of the repaint. I am trying to leave the factory color or as much of it as I can anyway. I know I can paint over the factory color but I don't know what the second paint job is. It looks like a base/clear job. If it's an early base coat it will likely shrivel when painted over. I can strip the outside body panels in a day but the inside surfaces are harder to do. Often the prep work for a repaint is little more than a quick sand with a skuff pad. The soda blaster is working nicely. its doing a nice job but slow going.
rick 918-S |
Jun 18 2010, 07:48 PM
Inside the front trunk..
rick 918-S |
Jun 18 2010, 07:58 PM
As I was stripping things off the car I discovered the right fender had been replaced. This was done early enough in the cars life that the entire fender was done. Who ever did the work did a nice job with the exception of the brass they used to weld it on. It's lucky this car was a west coast car all it's life or the braising would have been the kiss of death. I will likely just sand blast the channel and the entire inside mounting surface where the fender was joined to the car. With proper metal conditioning, priming and seam sealer (which there is none of now...) the car will be unaffected by the repair. I was suprised to see the lack of rust where the fender was attached and the seam sealer was not replaced on the inside wheel house.
iamchappy |
Jun 18 2010, 08:00 PM
Yum Yum a Raspberry Soda sounds refreshing on a hot Summers night......
rick 918-S |
Jun 18 2010, 08:04 PM
I picked up a really cool Blaupunkt AM/FM from Jeff Bowlsby.
jasons |
Jun 18 2010, 11:26 PM
rick 918-S |
Jun 18 2010, 11:41 PM
As I was stripping things off the car I discovered the right fender had been replaced. Wow! I had no clue. Its so hard to find a 914 with a clean history. Even here where its dry, most of them have some kind of rust at a minimum. Ya, I'm sure some kind of early accident. Really not a big issue as the rust around the brass is minimal. By the time I clean it up it will out last the car. Just came in from working on the trunk floor. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) |
bugsy0 |
Jun 19 2010, 12:17 AM
Member Group: Members Posts: 191 Joined: 26-July 06 Member No.: 6,508 Region Association: None |
(IMG:style_emoticons/default/agree.gif) absolutely crack me up - hilarious. I bet it doesn't look that pinkey-purple for real. |
bembry |
Jun 19 2010, 07:15 AM
Senior Member Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region |
I've missed the history on this car if in another thread. Was this a special order color car?
rick 918-S |
Jun 19 2010, 07:49 AM
I've missed the history on this car if in another thread. Was this a special order color car? Yes, The paint code is 98 This code covers a range of "special order Porsche colors" We (the 914 people on world, narp, club, pelican) have only located three in this 911 color. I have two of the three cars known. Here's a link to a thread started in 2005. http://www.914world.com/bbs2/index.php?sho...mp;hl=raspberry |
jasons |
Jun 19 2010, 08:39 AM
I have two of the three cars known. Actually, you have 1.5 of the known pink cars. (IMG:style_emoticons/default/biggrin.gif) |
McMark |
Jun 19 2010, 08:50 AM
You're soooooo greedy, Rick. (IMG:style_emoticons/default/stick.gif)
Sleepin |
Jun 19 2010, 06:27 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Rick has obviously been sharing his paint secrets with the Mustang world... (IMG:style_emoticons/default/blink.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i171.photobucket.com-8357-1276993653.1.jpg) |
jmill |
Jun 19 2010, 07:38 PM
That is very nice. Feel free to bring that soda blaster down South with you on your next vist. (IMG:style_emoticons/default/w00t.gif)
I just might have to pick one of those up myself. Let us know if your pleased with it. |
rick 918-S |
Jun 28 2010, 04:35 AM
That is very nice. Feel free to bring that soda blaster down South with you on your next vist. (IMG:style_emoticons/default/w00t.gif) I just might have to pick one of those up myself. Let us know if your pleased with it. The soda was everywhere! I have a spot along side of my garage where I was blasting. The ground was white with soda. It rained and it all disappeared into the soil. |
rick 918-S |
Jun 28 2010, 04:42 AM
I worked on the trunk floor repair panel. I decided to cut out the holes for access caps to give the trunk a factory look. This is not nessesary as these are really only used for access for the factory spot welders.
Lo-Fi Version | Time is now: 22nd December 2024 - 04:11 AM |
