> Suby Bremar plate info for DIY w/ pics!, linked to DIY coupling thread too!
Zaney
post Jun 13 2010, 10:12 PM
Deuchland en der Haus
Could someone who has already purchased the Bremar aluminum plate please measure the thickness of the plate and, post the thickness.
Thanks!
rickthejetman
post Jun 13 2010, 10:28 PM
QUOTE(Zaney @ Jun 13 2010, 09:12 PM) *
Thanks!
i made my own out of 1/8" plate from the pics i saw of theres it looked to be around 1/4" but i figured they made it that thick because of the machined in logo.
Zaney
post Jun 13 2010, 11:01 PM
QUOTE(rickthejetman @ Jun 13 2010, 09:28 PM) *
Thanks!
Would you mind posting pics of your finished plate?
Thanks for the info!
BIGKAT_83
post Jun 14 2010, 07:19 AM
Here you go....
Bob
rickthejetman
post Jun 14 2010, 07:33 AM
QUOTE(Zaney @ Jun 13 2010, 10:01 PM) *
Thanks!
sure i'll take a pic when i get home from work.
strawman
post Jun 15 2010, 02:08 AM
Thanks!
I just measured mine, and it is 0.32". But I don't think the thickness is critical, since it only appears to be keeping the gear oil in. Post pics when your plate is done!
charliew
post Jun 15 2010, 01:58 PM
I agree it's just a cover plate but I would make it at least 1/4 thick just so it will seal good at the flange. It is probably 8mm or .3144 from bremar.
Zaney
post Jun 17 2010, 01:53 PM
So, I took the pictures and advice from the members here and went to Everett Steel to see if they had a piece of aluminum in their remnant pile. Luckily, they had a 9 x 11 inch piece of 1/8 inch thick aluminum with someone's sign of "W.W.J.D". I think he would DIY! (IMG:style_emoticons/default/biggrin.gif)
Then, instead of using the poster board I cleaned up the nose cone and traced it directly to the cleaned up piece of aluminum.
I used these tools to make the plate from a $4.68 piece of aluminum (IMG:style_emoticons/default/piratenanner.gif)
Zaney
post Jun 17 2010, 02:01 PM
Next, i carefully drilled pilot holes in the plate and then chased them with the step drill bits to get the holes close.
I used a bolt to gauge how big the holes would be in the plate so I did not drill too big! For the shifter arm, drilled a hole in the plate then used a carbide drill bit to open up the hole to the traced dimensions. (IMG:style_emoticons/default/sawzall-smiley.gif)
Then, after all the holes (including the drift pin holes) were finished I used various metal cutting blades in my jigsaw to cut out the plate.
After I was close to the traced out lines I test fit the plate on the end of the trans.
It took a bit of feathering with the step drill bits and emery cloth to get every hole aligned properly. But it worked out great!
Zaney
post Jun 17 2010, 02:06 PM
I am very pleased with the outcome of this DIY plate! (IMG:style_emoticons/default/smilie_pokal.gif)
I had to go out and buy new bolts and hardware for the plate (20mm bolts instead of original 40mm in length) that came to $6.50.
So, instead of forking out $350 or so for the Bremar Kit I spent $11.00 and used 3 cutting wheels for the DIY Coupling.
So, here are the results!
And the final plate pic with silicone sealant on the trans to make it tight!!!
I recommend this method to anyone who wants to save $350 for the rest of their Suby project! Especially, coming from a novice like myself!
Cheers,
Nate
strawman
post Jun 17 2010, 02:10 PM
Atta boy!!!
jpnovak
post Jun 17 2010, 08:47 PM
They call me "Nanoman"
Glad to see my method of cutting the diff works.
I made the same aluminum plate from a 3/16" scrap I found in the garbage behind an industrial strip center. If you don't mind a little smell and dirt you can find things as good as gold.
- Lo-Fi Version Time is now: 19th April 2025 - 01:31 PM
