7 Pages V « < 4 5 6 7 >
> External Oil Cooler, let me see some pictures
tradisrad
post Dec 15 2010, 12:26 PM
Post #101
Rich, I like your idea.
-Rob
realred914
post Dec 15 2010, 12:27 PM
Post #102
Group: Retired Members
QUOTE(tradisrad @ Dec 15 2010, 10:26 AM) *
-Rob
what idea is that????
post May 16 2011, 09:19 PM
Post #103
QUOTE(BigD9146gt @ Jul 11 2010, 11:10 AM) *
Very coool...what's the cost?
Thanks!
cwpeden
post Jan 13 2013, 12:37 AM
Post #104
Great White North, huh?
(IMG:style_emoticons/default/WTF.gif)
QUOTE(rockyyy123 @ Jan 12 2013, 10:20 PM) *
hiii there ... (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif)
My leak began as a nothing leak. I thought it was just from running the air conditioner and within 2 weeks I had huge puddles under my car....... (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/drunk.gif) ..
Top Ten Classified website
Dave_Darling
post Jan 13 2013, 12:39 AM
Post #105
914 Idiot
It's spam. Just to get the link in the sig indexed.
Hopefully the post and the spammer will both be gone soon.
--DD
barefoot
post Mar 26 2013, 10:24 AM
Post #106
Do any of these systems incorporate in- line check valves in the lines to or from the cooler ?
I just bought 76 that is fitted with ex cooler and has check valve in line, not sure why needed (or if needed).
Comments ?
maf914
post Mar 26 2013, 01:51 PM
Post #107
Not a Guru!
QUOTE(barefoot @ Mar 26 2013, 08:24 AM) *
Comments ?
I would guess that the installer wanted to keep the oil in the external cooler and piping from draining back into the crankcase, resulting in a high oil level in the engine.
I have wondered about that occurring if the cooler is higher than the normal crankcase oil level. Is that an issue or problem? (IMG:style_emoticons/default/idea.gif)
Harpo
post Mar 26 2013, 02:04 PM
Post #108
Instead of the sandwich adapters I have seen an adapter that replaces the OE oil cooler. I don't remember where I saw it though. Basically it was a plate that had AN fitting that bolted replacing the cooler
David
barefoot
post Mar 26 2013, 03:45 PM
Post #109
QUOTE(maf914 @ Mar 26 2013, 03:51 PM) *
Comments ?
The cooler is presently mounted vertically to the underside of the rear trunk, so at about same level as sump. I just got car and it isn't running, but I'd like to reposition the cooler in the right rear fender well as I have air scoops into that area and it's then further from exhaust piping.
IGTARD
post Dec 11 2013, 07:05 PM
Post #110
IGTARD
International Space Station experiencing possible over heating. (IMG:style_emoticons/default/shades.gif)
tumamilhem
post Dec 12 2013, 07:57 AM
Post #111
LUFTBRIGADE
I'm glad for this thread. I want to install a second oil cooler on my LE, but because it's an LE, I don't want to chop it up. Any add-ons I do I am trying to do without performing surgery to its originality. So basically looking to just bolt on.
My other 914 has a second large oil cooler that is simply bolted to the floor pan underneath the car right before the engine bay opening. Being underneath the car it gets constant surrounding air, so there's no fan. This simple setup has worked fine for this car but I am not sure what the best placement would be for optimal functionality and protection.
Also, I'm not really sure what the best oil cooler to get would be. being in Florida I have very hot temperatures and drive my car year round. So I would like a larger cooler with optimal performance to help protect the duration of my engine and give me better performance. Also, if I need a fan a/o thermostat. I suppose living in Florida it's best to have the cooler operating whenever the car is on instead of just when it hits a certain temperature. Also I'm not familiar with this sandwich method that doesn't seem to be very popular.
From your expert opinions, what kind of oil cooler would you suggest I get? Where would you suggest I place it and how given my limitations of not chopping up my car? I did like the idea of it being turned at an angle underneath the trunk. Will this actually make it cooler by catching more air and having more oil in the cooler? And would it get enough air underneath the trunk? Also do I need a fan and thermostat? Any better suggestions than what I already have on my other 914 which is basically just a large cooler bolted underneath the floor pan forward from the rear wheels? Suggestions are much appreciated. Thanks!
JmuRiz
post Dec 12 2013, 09:24 AM
Post #112
QUOTE(tumamilhem @ Dec 12 2013, 05:57 AM) *
I had one under the trunk floor in my 2.0 with carbs. Worked like a champ, but mine had a manual one/off switch for the fan. A cleaner install would be to use a thermostatic switch to have the fan come on automatically when the temp get to the set point. I just used a sandwich plate at the oil filter to run to/from the cooler. Bolted to the trunk floor with rubber spacers to get the spacing and isolate from vibration.
But, you could always make a bracket to bolt to the transmission mount to eliminate a couple of holes in the trunk.
I still have the cooler/fan/lines in my parts bin.
I'm doing something similar but with larger cooling capacity in my /6 conversion.
Randal
post Dec 12 2013, 10:46 AM
Post #113
Re post #87: Nice installation, but be careful with that cloth braided line. Anywhere it rubs it will fray and then fail, especially if there is any pressure in the lines.
stugray
post Dec 12 2013, 06:11 PM
Post #114
I have one I might be willing to part with almost identical to the pic with thermostat switch.
It would be minus the sandwich adapter plate as I am going to use that.
gothspeed
post Dec 12 2013, 06:44 PM
Post #115
QUOTE(Harpo @ Mar 26 2013, 12:04 PM) *
David
Is this the setup you are thinking of?
http://www.autoatlanta.com/Porsche-914-Oil-Cooler-srch.html
ChrisFoley
post Dec 13 2013, 09:05 AM
Post #116
I am Tangerine Racing
QUOTE(Harpo @ Mar 26 2013, 03:04 PM) *
David
I have a batch of adapter plates for the cooler location sitting in a box here.
I also have some inline thermostats, and some block-off-plates for the tin.
I've been trying to find time to complete a kit which includes premade hoses between the adapter and the thermostat, with options for either a front or a rear mounted cooler.
gothspeed
post Dec 13 2013, 11:54 AM
Post #117
QUOTE(Racer Chris @ Dec 13 2013, 07:05 AM) *
David
That is a good idea ........ is tapping the oil cooler location better for the oil pressure, than the oil filter sandwich? Or is there no difference? ... (IMG:style_emoticons/default/popcorn[1].gif)
vw505
post Dec 13 2013, 12:13 PM
Post #118
Chris would it block the stock cooler?
ChrisFoley
post Dec 13 2013, 01:41 PM
Post #119
QUOTE(vw505 @ Dec 13 2013, 01:13 PM) *
Chris would it block he stock cooler?
It eliminates the stock cooler.
The air normally supplied to the cooler becomes available for improved cooling of cyls 3 & 4.
ChrisFoley
post Dec 13 2013, 01:52 PM
Post #120
QUOTE(gothspeed @ Dec 13 2013, 12:54 PM) *
David
That is a good idea ........ is tapping the oil cooler location better for the oil pressure than the oil filter sandwich? Or is there no difference? ... (IMG:style_emoticons/default/popcorn[1].gif)
I think its much better - for several reasons including improved oil pressure.
1) Added load on the filter circuit increases the likelihood that oil will bypass the filter unless the bypass valve is blocked.
2) A sandwich plate adds complexity (& drag) to the oil circuit - lowering the available pressure to the bearings.
3) The oil cooler inlet and outlet are already there on the block.
4) The stock filter mounted on a sandwich plate hangs down to where its hard to get past the engine crossbar.
5) More cooling air available for cyls 3&4
6) The stock cooler is inefficient in the stock location. Its adequate for stock engines but not so much for higher power rebuilds.
7) etc.
- Lo-Fi Version Time is now: 2nd April 2025 - 11:40 PM
