7 Pages V < 1 2 3 4 > »
> External Oil Cooler, let me see some pictures
tradisrad
post Jun 24 2010, 07:40 AM
Post #21
Can anyone fill me in on going to a full flow oil system?
campbellcj
post Jun 24 2010, 07:54 AM
Post #22
I can't Re Member
QUOTE(tradisrad @ Jun 24 2010, 06:40 AM) *
For a -4 or -6?
VaccaRabite
post Jun 24 2010, 07:55 AM
Post #23
En Garde!
For a 4
tradisrad
post Jun 24 2010, 08:46 AM
Post #24
QUOTE(Vacca Rabite @ Jun 24 2010, 06:55 AM) *
For a 4
thanks..
rwilner
post Jun 29 2010, 08:02 AM
Post #25
No Ghosts in the Machine
A member on club was/is selling their ride on ebay, and they had this pic of a very nicely installed front-mounted oil cooler. Not sure if it's full flow or not.
Here's the listing (no affiliation):
http://www.914club.com/bbs2/index.php?showtopic=214924
tat2dphreak
post Jun 29 2010, 09:59 AM
Post #26
stoya, stoya, stoya
I don't have pics, but I installed a 96-plate with an electric fan. it dropped my temps >20 degrees!
jhadler
post Jun 29 2010, 01:05 PM
Post #27
Long term tinkerer...
QUOTE(tat2dphreak @ Jun 29 2010, 07:59 AM) *
Where did you place the cooler?
-Josh2
tat2dphreak
post Jun 29 2010, 02:36 PM
Post #28
stoya, stoya, stoya
near the tranny, but, unlike the one above(post #10) I didn't mount it parallel to the trunk, it's at an angle to let more oil stay in the cooler and to let more air above it... the back bracket is lower... I'll try to remember to snap some pics
tat2dphreak
post Jun 29 2010, 05:45 PM
Post #29
stoya, stoya, stoya
went out and snapped a couple pics...
tradisrad
post Jun 30 2010, 08:28 AM
Post #30
I am getting clooser to installing my oil cooler. I am now gathering my last few parts and am wondering if those with a fan on the cooler are using a tempature switch to turn the fan on? And what switch is being used?
I don't want to put a switch on the dash or even worry about turning the fan on. So a switch that is controlled by the oil temp is what I am looking for.
The pelican article list several switched, but after aquick web search the switched no longer seem to be avaliable.
thanks
-Rob
tat2dphreak
post Jun 30 2010, 09:10 AM
Post #31
stoya, stoya, stoya
QUOTE(tradisrad @ Jun 30 2010, 09:28 AM) *
thanks
-Rob
I went switched, not thermostat. 1 less thing to fail... where I am only in the coldest weather would you want it turned off... so it just stays on... I put the switch in the engine bay. if the car is running, the fan is on... I didn't want it to try and cool oil that is already too hot. and a thermostat is one more thing to fail.
brp986s
post Jun 30 2010, 10:08 AM
Post #32
Elephant sells an adjustable fan switch (160 to 200 F). In use here on a 3.2. This car a factory -6 that I didn't want to hack up. This is just a street car so cooling requirements are not so high. Seems to do well. Temp measurements using an infrared thermometer are erratic, but there seems to be 20F difference in vs out.
tat2dphreak
post Jun 30 2010, 10:21 AM
Post #33
stoya, stoya, stoya
I like that mounting, but don't you lose the raintray?
brp986s
post Jun 30 2010, 10:25 AM
Post #34
No rain tray on a factory 6.
tat2dphreak
post Jun 30 2010, 10:49 AM
Post #35
stoya, stoya, stoya
QUOTE(brp986s @ Jun 30 2010, 11:25 AM) *
(IMG:style_emoticons/default/slap.gif)
duh, I knew that. idk what I was thinking.
naro914
post Jun 30 2010, 12:02 PM
Post #36
Losing my mind...
For Papa Smurf, we have the cooler mounted to the floor in the front trunk, with the air coming in the front bumper, through the shroud, through the cooler.
Pros and cons -
Pro - the air is heated AFTER it is leaving the front compartment space, so the shroud, and hence the front trunk, do not get hot.
Con - In effect, as in any 914 GT cooling set up, you are forcing hot air under the front of the car creating lift - exactly opposite of what you want in a race car. I have really started to notice the lack of downforce I have. For a street car, no big deal, but for a race car....not good.
I am considering moving this cooler set up to Huey (street car) so the front trunk area does not get so hot. For Papa Smurf, I am thinking of putting a normal front mounted cooler, and ducting into the wheel wells (similar to how a 911 cooling works)
this set up works really well. Engine is a high compression 2.2 with 200+/- hp, redlines at 7300 rpm. Both Nadine and I have driven it on the hottest days at the track, back to back runs, and temp never got above 200.
Pics:
tomeric914
post Jun 30 2010, 01:44 PM
Post #37
One Lap of America in a 914!
EDIT #1: Added picture and filter part number
EDIT #2: This location works great for a four cylinder car. However, putting even the biggest cooler (12" x 11" Setrab for example) under the trunk will work for around town when running a 3.0 six, but not so much at the track.
I've used the Derale Atomic Cool on 2 different application mounted next to the transmission with excellent results. There was at least a 20 deg drop in oil temperature if not more. What's nice is that the kit comes with a temperature switch.
I use the relay to enable the fan off of the + side of the coil. Main power for the fan comes direct from the battery with a waterproof fuse holder.
The sandwich adapter has a simple bimetallic spring that allows oil to flow once it reaches 180F. I also modified the oil filter mount to eliminate the spring loaded ball (so oil doesn't bypass through it due to the increased pressure drop of the oil cooler) and use a Baldwin B228 filter with an internal relief. It is the same length as stock, but a smaller diameter to clear the engine bar. (Save your breath, yes the filter has less area than the factory filter. It is more than sufficient for regular oil changes (IMG:style_emoticons/default/KMA.gif))
Here's the parts list from my Summit order:
QTY 2 - Fitting, Hose End, AQP Socketless, Straight, -8 AN Hose Barb to Male 3/8 in. NPT, Brass, Natural, Each
Part Number: AER-FBM1206
QTY 1 - Fitting, Hose End, AQP Socketless, 90 Degree, -8 AN Hose Barb to Female -8 AN, Aluminum, Red/Blue, Each
Part Number: AER-FBM1533
QTY 1 - Fitting, Hose End, AQP Socketless, 120 Degree, -8 AN Hose Barb to Female -8 AN, Aluminum, Red/Blue, Each
Part Number: AER-FBM1543
QTY 1 - Hose, AQP Socketless, Rubber, Blue, -8 AN, 10 ft. Length, Each
Part Number: AER-FCV0810
QTY 1 - Temperature Controlled Sandwich Adapter, Oil Filter, Sandwich, Aluminum, Natural, 3/4-16 in. Thread, 3/8 in. NPT Inlet/Outlet, Each
Part Number: DER-15702
QTY 1 - Derale Cooling Products Atomic-Cool Remote Fan Mounted Fluid Cooler, Tube-Fin Type, Aluminum, 9.375 in. x 12.75 in. x 4.313 in., -8 AN Inlet, Outlet
Part Number: DER-15950
QTY 1 - Relay, Starter/General Use, 30 Amp, Single Pole, Each
Part Number: VIA-80237
tradisrad
post Jul 11 2010, 10:21 AM
Post #38
Oil cooler is installed. I mounted it under the rear trunk, ran the cooler lines through the engine compartment, added a thermostaticly controlled fan.
I am able to keep my oil temps down around 180 to 190 with the fan running. I pulled the fan fuse and noticed the temps climb into the 210 range. I am pleased with the outcome.
Oil cooler:
Lines passing into the engine compartment:
Mocal adapter:
My next part of the project will be to add a small LED in the oil temp gauge to indicate when the fan is on. But it may be a while....
BigD9146gt
post Jul 11 2010, 12:10 PM
Post #39
OCD member
Region Association: Australia and New Zealand
Heres a hardline setup I made for a 912E... The customer wanted the stock front mount 911 oil cooler setup. Used a Mocal sandwich thermostat.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i97.photobucket.com-3502-1278872083.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i97.photobucket.com-3502-1278872083.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i97.photobucket.com-3502-1278872084.3.jpg)
realred914
post Jul 11 2010, 12:32 PM
Post #40
Group: Retired Members
I dont like the idea of dumping hot air from tehoil cooler back in to the engine bay, that adds hot air to the cooling system and air intake. the idea is to dump the heat from the oil outside of the engine bay. Not put it back into the engine.
- Lo-Fi Version Time is now: 2nd April 2025 - 01:39 AM
