> Model Specific Information
3 Pages V  1 2 3 >
> Fuel Evaporative Control System-AKA Charcoal Canister, More information than anyone wants to know
JeffBowlsby
post Jun 29 2010, 01:13 PM
So how does this system work? Review these first two graphics from the factory repair manual to find out.
(PS I wonder why the forced induction guys dont't use the air from the fan housing to spin their turbos? (IMG:style_emoticons/default/confused24.gif))
JeffBowlsby
post Jun 29 2010, 01:28 PM
Then as a test, whats wrong with the charcoal conister installation on these diagrams? The first one is in the factory repair and Service and Training Manuals.
When you are done with this I have more...
JeffBowlsby
post Jun 29 2010, 01:29 PM
post Jun 29 2010, 02:22 PM
Resident German
QUOTE(Jeff Bowlsby @ Jun 29 2010, 12:28 PM) *
They both show the air from the fan shroud go into the wrong end on the canister ...
The pressure side on the canister is on the side with the two nipples. Fresh air and vapors come in from the same side. The vapor/air mix is then expelled on the drivers side of the canister and routed to the engine air-filter housing ...
What do i win?
(IMG:style_emoticons/default/biggrin.gif) Andy
JeffBowlsby
post Jun 29 2010, 02:39 PM
Jahvol Mein Freund (IMG:style_emoticons/default/biggrin.gif)
Win? HA! This is a documentary...
But wait there is more. The later plastic case charcoal canisters can be opened up and the activated charcoal can be replaced (check Google for suppliers). This should be done...every 50K miles according to the repair manual.
Pat Garvey
post Jun 29 2010, 06:52 PM
Do I or don't I...........?
Jeff, you know you had to open a "can 'o worms" here.
What about the older cars? I was told by the local PD (dealer) in about '75/76 that the canister was self healing, in that it would clear itself & rejuvinate itself over time - like I believed that!
Charcoal has limited capabilities of absorbing hydrocarbons. Yes, it works fine for a few yeas of normal driving, but then it becomes, in the case of these pellets. over absorbed.. I suppose after that some " parked time" the pellets could clear of hydrocarbons, but would then absorb ambient moisture. Bad? Not certain, but I think so. And, when that moisture is released to the chamber & tank, corroson might occur.
Now, I seem to remember that there was a maintenance bulletin that recommended changing the canister on the early cars at around 50K. By that time (one my 914) they were unavailable.
So, given that my 914 is 37 years old, and isn't required to have emission testing in PA, would I be better off bypassing the canister? Is it of any value at this point?
Pat
JeffBowlsby
post Jun 29 2010, 10:30 PM
Well Pat...
You can see the factory manual recomendaiton above indicating replacement at 50K intervals. Thats all I know. I dunno nuthin' 'bout the mineralogical properties of the activated charcoal, bet Google knows.
I believe its primarily an emissions thing...filtering raw hydrocarbons from the air (the fuel tank is not pressurized, its open to the atmosphere). If people smell gas in their cabins, it must be a faulty hose, loaded-up charcoal canister or some other flaw in the system.
OR, you could find an NOS charcoal canister correct for your model year...OR you could locate a later-issue <gasp> plastic canister and change out the charcoal as in the above picture.
Next chance I get I will post photos of the different styles of canister and their different locations...
How many different canister styles were their? How many different mounting locations? (IMG:style_emoticons/default/confused24.gif)
JeffBowlsby
post Jun 30 2010, 10:03 AM
A 1970 model
JeffBowlsby
post Jun 30 2010, 10:04 AM
VIN 4712908458
JeffBowlsby
post Jun 30 2010, 10:05 AM
VIN 4722907659
JeffBowlsby
VIN 4732903509
JeffBowlsby
post Jun 30 2010, 10:06 AM
VIN 4732914926
JeffBowlsby
VIN 4732926371
JeffBowlsby
post Jun 30 2010, 10:07 AM
VIN 4742905929
JeffBowlsby
VIN 4742915964
JeffBowlsby
post Jun 30 2010, 10:09 AM
From the 1975 Service and Training Manual
JeffBowlsby
VIN 4752903075
JeffBowlsby
post Jun 30 2010, 10:10 AM
VIN 4762901268
post Jun 30 2010, 10:37 AM
Resident German
QUOTE(Pat Garvey @ Jun 29 2010, 05:52 PM) *
When i removed mine ('70 914-4), i opened it up to have a look inside. It was empty! (IMG:style_emoticons/default/huh.gif)
I guess after 30+ years, all the charcoal inside had turned to dust and was happily burned by my engine ...
(IMG:style_emoticons/default/popcorn[1].gif) Andy
Peter Zimmermann
post Aug 23 2011, 04:11 PM
QUOTE(SirAndy @ Jun 30 2010, 08:37 AM) *
FWIW; this is the only suitable place I could find on my '74 1.8 (VIN 7173). There were no holes in the left side body to bring the lines forward from the shroud/air cleaner, and the car did have the 5mm plastic line in the tunnel. Result? No fuel smell at all in the car or garage.
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 19th April 2025 - 12:23 PM
