BarberDave |
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest ![]() |
I need to replace my drivers seat, (recovering it is cost prohibited) I have a line on a perfect passenger seat. Can I switch mounting rails and everything from the old drivers seat to the new passenger seat. Will that work and fit????? Dave (IMG:style_emoticons/default/slap.gif) |
partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
(IMG:style_emoticons/default/smilie_pokal.gif) I need to replace my drivers seat, (recovering it is cost prohibited) I have a line on a perfect passenger seat. Can I switch mounting rails and everything from the old drivers seat to the new passenger seat. Will that work and fit????? Dave (IMG:style_emoticons/default/slap.gif) Can a person swap the rails? |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Yes to both of you.
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
It won't be concours anymore... (IMG:style_emoticons/default/lol-2.gif)
windforfun |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,894 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() |
Passenger seatbelt sensor?
TheCabinetmaker |
sensor is wired to the seat pad, not the seat itself. They are most all unplugged by now anyway. LOL
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Headrests will be wrong. They are angled to be higher in the center. It'll look wrong through the back window. Otherwise it will work.
pcar916 |
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None ![]() ![]() |
The mounting holes for the tracks on mine were slightly different. So the pass. seat slides with a little more effort than it used to, but it works.
windforfun |
sensor is wired to the seat pad, not the seat itself. They are most all unplugged by now anyway. LOL Mine works fine. I had to replace the sensor. The first one's inside wire insulation had turned to powder. Kind of strange. (IMG:style_emoticons/default/dry.gif) |
TheCabinetmaker |
Headrests will be wrong. They are angled to be higher in the center. It'll look wrong through the back window. Otherwise it will work. Wow. I just measured headrest on 13 different seats. They were all exactly the same. (IMG:style_emoticons/default/confused24.gif) |
BarberDave |
WOW, You mean this is one of my crazy ideas that will work!!!!! Thanks to all that chimed in. Dave (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/piratenanner.gif) |
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
isn't there a recess for the handbrake on the drivers seat?
windforfun |
poorsche914 |
T4 Supercharged ![]() ![]() ![]() ![]() Group: Members Posts: 3,093 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States ![]() |
isn't there a recess for the handbrake on the drivers seat? Yes, there is a recess: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1278099381.1.jpg) |
windforfun |
You're very observant. Now I'm dying to check mine. Thanks.
jmill |
Wow. I just measured headrest on 13 different seats. They were all exactly the same. (IMG:style_emoticons/default/confused24.gif) I'll measure the 2 sets I have. I could swear they look different. (IMG:style_emoticons/default/unsure.gif) |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
The headrests on mine are angled different
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,712 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
The headrests on mine are angled different (IMG:style_emoticons/default/agree.gif) I have a passenger seat as my driver seat and you can tell by the angle of the headrest when looking at them through the back window ... (IMG:style_emoticons/default/popcorn[1].gif) Andy |
jmill |
Yup, just like I remembered. Even Stevie Wonder can tell there's a difference.
Attached thumbnail(s) ![]() ![]() |
windforfun |
Right on!!! Porsche could have reduced production costs if they had made them the same.
Lo-Fi Version | Time is now: 1st July 2024 - 06:36 AM |
