111.905.865 K, Ignition Start Switch |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
orthobiz |
Jul 18 2010, 01:08 PM
Senior Member Group: Members Posts: 1,757 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Two Switches: OEM and Aftermarket
First: OEM in packaging |
orthobiz |
Jul 18 2010, 01:12 PM
Next: Looking into the switch. OEM is pale on the left and has copper contact showing. Aftermarket is greenish on the right and has white plastic in the middle.
orthobiz |
Jul 18 2010, 01:18 PM
Two peas in a pod, side by side. OEM left, Aftermarket right (aftermarket is a bit dirtier even though it is unused).
orthobiz |
Jul 18 2010, 01:22 PM
I know, enough already with the pics! Two more. The OEM has a yellow dot and is on the RIGHT in the left pic. Still on the RIGHT in the right pic, the aftermarket has a little X that I put there so I wouldn't confuse the two.
McMark |
Jul 30 2010, 01:03 AM
Just the right amount of pics! Any less and it wouldn't be as helpful. (IMG:style_emoticons/default/smilie_pokal.gif)
Lo-Fi Version | Time is now: 26th December 2024 - 12:41 PM |
